Author Topic: 2.5td smoking  (Read 3919 times)
cdbdiis
2.5td smoking
« on: 11 March 2008, 20:58:16 »
Hello everyone, I'm new here by the way !
Anyway I have an M reg 2.5td auto estate and the fuel consumption is terrible, at best 25 mpg at worst I dare not calculate it ! There is a lot of black smoke from the exhaust, could the two things be connected ?
My suspicion is the pump timing, can anyone tell me how this is adjusted or are there any other opinions ? The car is relatively new to me and has covered just on 160,000 miles it will be used to tow a car transporter trailer.
Thanks
Re: 2.5td smoking
« Reply #1 on: 11 March 2008, 21:03:01 »
Thanks
Could well be the chain has slipped - happens with people do not change oil as per schedule (every 4.5k MAX) on these engines  :'(
Could also be a simple sensor issue, but you'll need to get it hooked up to a Tech1 to read it...
cdbdiis
Re: 2.5td smoking
« Reply #2 on: 11 March 2008, 21:37:18 »
thanks, "but you'll need to get it hooked up to a Tech1 to read it..."
I've read quite a lot about this, how do you go about it and what is it likely to cost ?
M Kerr
  • Birmingham
    • 2.5 GLS Omega, X Type
Re: 2.5td smoking
« Reply #3 on: 11 March 2008, 21:39:57 »
Black smoke from diesels can be caused by timing or worn injectors.  Timing can be fairly easily adjusted but best left to someone with reasonable knowledge.  Given the mileage it is possible that recon'd injectors might be required.  Possible both.  It shouldn't cost too much to get the timing checked and adjusted if required so try this first.  I won't put a price on injectors but you'll dip into your pocket if they need changing.  The job is easy but the parts cost a bit!
Cheers,
Martin
Re: 2.5td smoking
« Reply #4 on: 11 March 2008, 21:46:47 »
Need to find someone with a Tech1 near you.  A Tech2 will not read that engine.
waspy
Re: 2.5td smoking
« Reply #5 on: 11 March 2008, 21:48:53 »
My first thing to look at before we get technical is- check for obstructions in/around the air filter box. The Rover Diesel of old where known to suck up plastic bags & debri. It happened to me with a misplaced rag that my mate used to check the oil.
Black smoke galore
You never know  ::)
cdbdiis
Re: 2.5td smoking
« Reply #6 on: 11 March 2008, 21:49:06 »
I spend a lot of time at Silverstone.... not far from Northampton, can you see where this is going  ;D
Re: 2.5td smoking
« Reply #7 on: 11 March 2008, 21:51:30 »
I actually live near Silverstone, a small town called Brackley.
Unfortunately, I do not own a Tech1 :(
cdbdiis
Re: 2.5td smoking
« Reply #8 on: 11 March 2008, 22:01:19 »
No probs ! Can I reasonably expect to get 35mpg out of it when it's sorted, mixed driving A-B roads ?
Re: 2.5td smoking
« Reply #9 on: 11 March 2008, 22:05:36 »
i get 37 from my tractor, though is chipped
cdbdiis
Re: 2.5td smoking
« Reply #10 on: 11 March 2008, 22:31:55 »
So how is the pump timing adjusted ?
Re: 2.5td smoking
« Reply #11 on: 11 March 2008, 22:38:23 »
3 bolts hold in place, when loosened, you can rotate it slightly.  A gauge is put in back of pump to get it timed right.
If it has jumped a tooth (or the plastic guides broken), there won't be enough adjustment, plus it will happen again. The solution to that is changing the chains and guides - thats a head and sump off job sadly (silly BMW design!)
If the pump timing has moved/slipped, I think that is a job best left to a specialist with the right equipment :(
Hopefully it will not be that, and it is a simple sensor issue (I am assuming you have checked obvious like filters etc
cdbdiis
Re: 2.5td smoking
« Reply #12 on: 11 March 2008, 22:49:53 »
Right so with the Tech 1 it should be possible to check sensors etc. ?
Will this also reveal an out of time pump ?
Great informative forum you have here by the way  :)
Re: 2.5td smoking
« Reply #13 on: 11 March 2008, 22:57:53 »
Tech1 will show if ECU not happy with sensors.
Its not the easiest bit of kit to use for live data views for in depth analysis though.
cdbdiis
Re: 2.5td smoking
« Reply #14 on: 12 March 2008, 18:39:38 »
An update on this then.
After removing the air filter and driving the car with the top of the filter casing lifted off, not recommended I know but it's do or die, there was a marked improvement both in smoke output and performance. After some initial smoking it cleared completely.
I could find no blockage in the inlet piework going to the air filter housing but the flexible pipe was detached completely (2" gap) from the plastic inlet tube behind the grille. Could this be the problem ?
Before I found the pipework problem I fitted a new air filter and it went back to how it was.
« Last Edit: 12 March 2008, 18:42:52 by cdbdiis »
