Author Topic: What to lube?  (Read 2438 times)
estaszew
  • USA, Long Beach, California
What to lube?
« on: 11 March 2008, 19:17:10 »
What should be lubricated regularly (specifically with every oil change)?  Everything seems sealed so it's hard for me to tell.  I was considering giving the shocks a little Gibbs penetrant/lubricant, but I don't know if it is advisable or necessary.
The Doctor
  • Wolverhampton
Re: What to lube?
« Reply #1 on: 11 March 2008, 19:35:14 »
If your keen, Door check strap, exterior lock barrels, hinges inc boot and bonnet, bonnet release catch and lock mech in the engine bay.
my first thoughts.
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: What to lube?
« Reply #2 on: 11 March 2008, 20:54:22 »
Normally just the shaft but if the housing is too tight it might need a bit too....   ::) ::) ::) ::)
Sorry couldent resist   ;D ;D ;D ;D
Gaffers
Re: What to lube?
« Reply #3 on: 12 March 2008, 11:50:40 »
I take it nobody appreciated my filthy sense of humour  :-[ :-[
Re: What to lube?
« Reply #4 on: 12 March 2008, 13:03:28 »
Was just waiting for you to realise you forgot the warning about the oil supply getting clogged on higher mileage vehicles.  :-X
Gaffers
Re: What to lube?
« Reply #5 on: 12 March 2008, 13:10:11 »
not that im an expert but I thought it had more to do with age than milage....   :y
Re: What to lube?
« Reply #6 on: 12 March 2008, 15:33:51 »
I see little late ;D ;D :y
Re: What to lube?
« Reply #7 on: 12 March 2008, 17:37:58 »
Probably true. Infrequent use and short journeys don't help either.
So I'm told.  ;D
perfferle
  • North Yorkshire
  • All cats are grey in the dark!
Re: What to lube?
« Reply #8 on: 12 March 2008, 19:33:44 »
I have been following this thread and was curious if the lube type especially for door locks is important -
After using multipurpose grease - I have been having frozen door locks in cold weather- the door would unlock and open but would just bounce open again when trying to close the doors :(.
P.
Re: What to lube?
« Reply #9 on: 13 March 2008, 00:01:36 »
P.
Could be a door locking motor on its' way out. I have the same problem at the moment. >:(
HerefordElite
  • Hereford
  • Welcome to the Shire
Re: What to lube?
« Reply #10 on: 13 March 2008, 00:13:10 »
P.
same here they freeze up so you can't get in :D, then when you can open them they bounce and won't shut :D, then when i get to work i can't open again and have to climb out 'Dukes of Hazzard' styleee ;D ;D ;D
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
Re: What to lube?
« Reply #11 on: 13 March 2008, 22:19:32 »
PM with your requests.
perfferle
  • North Yorkshire
Re: What to lube?
« Reply #12 on: 13 March 2008, 22:32:55 »
Ok Ok,
That's a funny as hell ;D ;D :y
