towbar 2.5 98 elite
Started by irratic, 13 March 2008, 17:32:23
Quoteconnected wiring up everything great....except i cant get brake lights, ive connected just behind the trailer plug... is it easier me taking it off the light cluster?? or shorting the two pins on the relay?? which pins??there is no buzzer in the line..( i wouldn't hear it with the styereo anyway)
As said the loom in the boot relies on you using the trailer brake light check 'relay' which is above the driver's feet in your car. . Either put the relay in & you will monitor your trailer brake lights as well as the car's or bridge the terminals - Black/yellow wires seem to ding a dong (without me looking for my Haynes & the wiring diags  ::)) As Weds says though the brake light isn't too far away to take a feed.
