Author Topic: Dis help URGENT  (Read 4770 times)
106rallye
  • Glasgow
Dis help URGENT
« on: 15 March 2008, 15:22:31 »
Hey guys.
Im in the middle of changing the dis pack and for the life of me i cant get the dam thing out! everthing is off it but i cant find a hold big enough for it to fit through and get the new one in, tried both the top and the bottom. help please  :'(
sideways is the way forward!
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: Dis help URGENT
« Reply #1 on: 15 March 2008, 15:25:17 »
I take it the scuttle is off??
You might have to remove plenum.... very quick just use a bit of oil on the O rings when replacing
106rallye
  • Glasgow
Re: Dis help URGENT
« Reply #2 on: 15 March 2008, 15:27:57 »
naa cant remove scuttle, the wipers are seized on and i dont have a puller
Gaffers
Re: Dis help URGENT
« Reply #3 on: 15 March 2008, 15:36:30 »
so were mine when I first tried.  Put a squirt of wd40 in the wiper bolt area tap it lightly with a small hammer and then just wriggle it like f%$£, particularly in and out toward the windscreen and out and it will come off.
106rallye
  • Glasgow
Re: Dis help URGENT
« Reply #4 on: 15 March 2008, 18:14:11 »
The car is doing my head in! got everytthing back together, leads on the same way, but when i try to start it its as though they are on wrong! im ready to burn this thing!
Re: Dis help URGENT
« Reply #5 on: 15 March 2008, 18:16:48 »
Just double check passenger bank leads - the order is odd on the DIS...
106rallye
  • Glasgow
Re: Dis help URGENT
« Reply #6 on: 15 March 2008, 18:27:12 »
ive double and triple checked it against what i have wrote down (which im starting to think must be wrong)
Does anyone know if this is right?
106rallye
  • Glasgow
Re: Dis help URGENT
« Reply #7 on: 15 March 2008, 18:28:33 »
they numbers arnt the firing order, just what i numbered the leads when i was doing the rocker gaskets
Re: Dis help URGENT
« Reply #8 on: 15 March 2008, 18:43:44 »
That looks wrong to me...
Re: Dis help URGENT
« Reply #9 on: 15 March 2008, 18:47:03 »
Cylinder order is
BACK
         6
5
         4
3
         2
1
FRONT
Still looking for DIS order, from memory its
1 3 5
2 6 4
but hopefully someone can confirm the DIS bit first
Re: Dis help URGENT
« Reply #10 on: 15 March 2008, 19:02:48 »
1 3 5
2 6 4
Mine is (from a note I made when I changed mine)
4   6   2    p
                 l
                 u
1   3   5    g
Re: Dis help URGENT
« Reply #11 on: 15 March 2008, 19:04:30 »
1 3 5
2 6 4
4   6   2    p
                 l
                 u
1   3   5    g
Yours sounds correct :y
106rallye
  • Glasgow
Re: Dis help URGENT
« Reply #12 on: 15 March 2008, 19:17:46 »
1 3 5
2 6 4
4   6   2    p
                 l
                 u
1   3   5    g
right now im really confused, i changed it to that and its not starting at all, before it would run really rough for a few secs then die, now as soon as it catches its dying  :'( its to dark now so will have to look at it again tomorrow but i have no idea whats wrong
106rallye
  • Glasgow
Re: Dis help URGENT
« Reply #13 on: 16 March 2008, 16:45:14 »
ok ive checked every single thing 3 or 4 times, everything is in the right order, nothing else is unplugged, tried it with new HT leads and nothing. and to top it all off i think the started as packed in!
only thing i can think of is the park that im trying to fix is damaged, can anyone think of anything else?
MutantCav
  • Gainsborough
Re: Dis help URGENT
« Reply #14 on: 16 March 2008, 16:52:33 »
Is that order correct for the older 95 dis packs?? Only the connector is on the top on the older ones not at the side?? Are the older dispacks different??
