Author Topic: Flushing with degreaser  (Read 1308 times)
Albus Dumbledore
  • Bergen, Norway
« on: 15 March 2008, 08:31:55 »
How do you flush the cooling system with degreaser? Step by step?
hotel21
  • The Kingdom of Fife
Re: Flushing with degreaser
« Reply #1 on: 15 March 2008, 09:40:27 »
When I done mine, I drained out some water when it was cold thenpoured about a cupfull of neat Gunk into the header.  Left the header tank cap off then run it up until warm to ensure air is out.  Heater on full.
Replaced cap and drove it for about 10 miles or so to ensure all was thoroughly mixed.  I then let it cool down for an hour or so then drained it all out from the radiator drain.  Refilled with fresh water, ran it for another handfull of miles then drained down again.  Repeated several times until the water was clear with no sign of the gunk or cloudyness.
I have also left the drain tap open with a garden hose into the header tank such that the water flowing in balances that flowing out the drain, if you follow.....
Once happy, drained it down and refilled with the correct proportion of neat VX red antifreeze then topped up with water.  Ensure you get all the gunk out as well as any airlocks and all should be fine.
« Last Edit: 15 March 2008, 09:45:04 by hotel21 »
Albus Dumbledore
  • Bergen, Norway
« Reply #2 on: 15 March 2008, 09:49:36 »
OK, thank's:)
I will try:) Problem is I have had about 15 litres of engine oil in the cooling system:(
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #3 on: 18 March 2008, 19:23:33 »
i had a prob with a cav red top that had porus heads, and i used a low foam washing detergent  in the cooling system and then drove 20 mile then drained and repeated several times untill it was clear of mayo. flushed another several times and then refilled with vx red coolant to a 50/50 mix. worth trying mate. :y
Jaguar XJ6
