Author Topic: condonsation build up in oil filler  (Read 4226 times)
grim
  • sunny felixstowe,suffolk
« on: 19 March 2008, 07:29:06 »
hi,i have a 2.5 petrol,i use it for big fishing trips all over the country and france,it runs with no probs,but unfortunatly i work about 3 miles from where i live,hence it does a lot of short journeys and i get the impression that these cars dont like it too much as i get white sludge build up just inside oil filler(about half an eggcup full a fortnight).i dont believe its head gasget as i clean sludge away from cap,do a 300 mile journey,and its still nice and clean with no oil/water loss...is there something i could do to minimise this except do a lot of miles regulary
2.5cd,been to the moon and back and still ext_0 like new
Timbuk
  • Telford
  • owned a Datsun 120y once!
Re: condonsation build up in oil filler
« Reply #1 on: 19 March 2008, 07:35:26 »
Its completely normal and nothing to worry about ;)
grim
« Reply #2 on: 19 March 2008, 07:38:55 »
shall i continue to clean it or just leave it,thanks
« Reply #3 on: 19 March 2008, 08:32:14 »
Whose oil do you have in it. Apparently Vx's own semi-skimmed is less prone to emulsifying (sp?)
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #4 on: 19 March 2008, 08:37:33 »
its normal on v6`s on short runs particularly in the cold weather.
Peronally i clean it off ad hoc and ensure the car gets a decent motorway blast and very regular servicing...that combination does the trick.
« Reply #5 on: 19 March 2008, 08:57:23 »
same here :y
« Reply #6 on: 19 March 2008, 09:38:02 »
.. and pay extra attention to making sure the breathers stay clean if it gets short journeys.
grim
« Reply #7 on: 19 March 2008, 16:38:59 »
hey thanks for all the info,i use shell helix,its what vauxhalls main dealer puts in it,its had plenty of regular servicing(last one only 4000 miles ago).think ill check out the breathers just to make sure,cheers again  :y
davlad22
  • Sunny Yorkshire
« Reply #8 on: 19 March 2008, 16:39:40 »
Drive it like you stole it  :y
Danny
  • Wigan, Greater Manchester
« Reply #9 on: 19 March 2008, 16:40:10 »
... and run it down a motorway too :y
Martin_1962
« Reply #10 on: 19 March 2008, 16:58:35 »
That's wrong - drive it like you are chasing someone who stole another ;D ;D
Danny
« Reply #11 on: 19 March 2008, 17:09:42 »
drive it like you care!!!
achoo81
  • Exmouth Devon
« Reply #12 on: 19 March 2008, 20:38:05 »
Try getting hold of a piece of felt about 3to5 mm thick cut it to the length of the filler neck and wide enough to go round it and overlap by 25 mm or so then wrap it round the neck and fix in place with a couple of cable ties. This is a trick I learnt to stop the same thing on the old Viva which was very prone to it.
It happens because the filler cools down faster than the rest of the engine that causes condensation which mixes with the oil the result is the mayo.
« Reply #13 on: 19 March 2008, 22:01:08 »
In the case of the V6, it occurs because its the higest point in the engine so water vapour tends to boil off and up to this point. Unlike most engines, because the neck is tall, it doesn't get much oil splash from the cams which would normlay disperse the stuff.
I have to say I dont rate the basic shell oils.....
rad cap
  • manchester
« Reply #14 on: 19 March 2008, 22:05:34 »
drive it like you stole it, see you on cop road wars soon,  ;)
