Author Topic: Engine light and stall (Wreg 2.0 Auto)  (Read 3966 times)
Re: Engine light and stall (Wreg 2.0 Auto)
« Reply #15 on: 22 March 2008, 13:41:07 »
Not wanting to hijack Canon's thread, but seeing as I said I'd post diagnosis....I got 335; 340; 352 or, as far as I can gather, Crank sensor; camshaft sensor; Ignition coil 1&2. Perhaps someone could confirm? All look pretty scary and obviously thoughts, input, advice gratefully received.
Start a new thread ;)
Womega
« Reply #16 on: 22 March 2008, 17:26:22 »
Done, in General Help forum under title: Paperclip diagnosis: 335; 340;352...  further input welcomed :y
Canon Cam
  • Ferdown/bournemouth
« Reply #17 on: 23 March 2008, 19:04:06 »
Ok, I removed the MAF sensor from the air pipe.
One side (side facing into airlfow (or towards air filter box) was slightly carbonised, blackening on the wire.  I cleaned that up using some isopropynol 99% alchohol and q-tip and refitted.
Would it make any difference - I have also put it back in facing the other way (althoug electro connector correctly fitted (so whole unit rotated by 180%.
Next job I guess would be to clean the icv and pipes.
BTW, no air leaks anywhere that I could tell.
