Author Topic: WHat is cooling system pressure?  (Read 2024 times)
Martin_1962
« on: 28 March 2008, 19:29:35 »
PSI BAR whatever, need to see if my bodge will work
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: WHat is cooling system pressure?
« Reply #1 on: 28 March 2008, 19:35:15 »
at a guess I would say about 30-40 psi, but I am sure someone with more scientific knowledge will give you a better answer soon  :y
« Reply #2 on: 28 March 2008, 19:45:39 »
It's not too high. Perhaps 10 or 12 PSI. I forget what the expansion tank cap is rated at but it may be stamped on it. That's the ultimate limit to the pressurisation.
« Reply #3 on: 28 March 2008, 19:56:16 »
12 ish Psi....
Martin_1962
« Reply #4 on: 28 March 2008, 20:11:12 »
12 ish Psi....
Will alradite hold a copper pipe glued into a nylon pipe?
I hope so as I need to hunt for a new T piece
« Reply #5 on: 28 March 2008, 21:22:42 »
12 ish Psi....
Chose the right araldite, it has a habit of softening when warm and roughen it all up well first so it gets a good key.
Martin_1962
« Reply #6 on: 29 March 2008, 11:50:06 »
12 ish Psi....
Couldn't find slow set and rapid didn't work - have some 2nd hand tees on their way!
Big_Roger
  • Southampton
« Reply #7 on: 29 March 2008, 18:01:55 »
Hi,
Some while back I made up a tee piece with Schreader Tyre valve in it so I could fit in the system to pressurise it cold to check for leaks.
I found the header tank pressure cap started to release at just over 13 PSI.
HTH
Roger
Be patient ! Something else will go wrong for you to fix if you wait long enough !!
