Author Topic: Thermostat change 3.0 V6  (Read 4102 times)
ScottieMV6
  • Swinton, Manchester
« on: 28 March 2008, 18:45:37 »
Hi
Anyone give me an idea of how easy/hard it is to change the thermostat on a V6??
Does anyone have a How 2 guide for it?? I have had a look on here and can't find one.
Thanks
Scott
I'd rather be scared to death than bored to death!!
Dazzler
  • Haverhill, Suffolk
Re: Thermostat change 3.0 V6
« Reply #1 on: 28 March 2008, 19:07:33 »
About 3 hrs, you need to strip off the plenum, injector rail and in let manifold. This gets you to the heart of the V where the thermostate lives.
Then you will need to remove the transfer pipe to the thermostate and then the state itself
Mike Collins
  • North of Bristol
« Reply #2 on: 28 March 2008, 22:36:08 »
In practice you may find it rather difficult to separate the transfer pipe from the the housing.
Moving the power steering reservoir out of the way will make access to the the transfer pipe bolt easier, but still challenging.
I have given up on separating the joint and use a small die grinder to cut a slot in the thermostat housing. A large screwdriver blade can the be used to crack the pipe and allow movement.
You are going to throw the old housing away in any case.
One of the thermostat bolts is threaded into the waterway, use sealant on reassembly.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #3 on: 28 March 2008, 23:14:44 »
Like already said above Plenum, Inlet manifold and flange to be taken off. I undid the thermostats two torx bolts and got my grips on it wiggling it free from the Transfer Pipe first (as you will be replacing it anyway).
Then again like above, undo the bolt that holds the Power Steering Reservior and move it towards the bulkhead so the pipe moves out of the way of the "Problem Bolt!" it really isn't that much of a problem to get out (but getting it back in seems to be the problem.. There are three things that share the bolt, an engine lifting bracket, dipstick and Transfer pipe, just make a note of which order they go in.. then the bolt will go back quiet easy).
Once you have removed the bolt you will need to turn the transfer pipe anti clockwise to get it out of the way of the dipstick. (I removed the Transfer Pipe but next time I wont) just slide it out enough to get the thermostat housing out.
Replace the two "O" rings on the end of the transfer pipe (then i put a smear of grease over them so it slides easily into the thermostat). Refit the new thermostat and bolt it down, slide in the transfer pipe, turn it clockwise around the dipstick now making sure you have the three things in order replace the problem bolt. Refit the Power Steering Reservior and Job Done :y
trebor
  • Swindon
« Reply #4 on: 29 March 2008, 00:24:29 »
I wish it was that easy!  Had a bit of a 'mare doing mine...bloody awkward  bolt.  Also the top pipe had the old type clamp clips - extremely difficult to get to and get off..
luv_my_mv6
  • Northwood (London)
  • Just one thing after another
« Reply #5 on: 29 March 2008, 01:11:17 »
Dont do it!!!! I did mine a couple of months ago, and believe me, I would have paid very well for someone to have done it, my knuckles and hands were in tatters when i'd finished, it took me nearly 4 hours to do, partly because the housing was well and truly stuck tight, and there is no room at all to seperate the housing from the block without damaging it, in the end, I looked on fleabay for the part, and manually and litterally ripped the old housing off - and it took some effort  :-X You may be ok tho, every car is different, I had the old bill servicing mine before I bought it so that says something "never rely on a police car to get you from A to B"  ;D
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #6 on: 29 March 2008, 11:31:53 »
Replace them with a jubilee clip easier to tighten up :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #7 on: 29 March 2008, 11:33:03 »
Perhaps a thermostat party is needed ;D
hotel21
  • The Kingdom of Fife
« Reply #8 on: 29 March 2008, 11:34:18 »
not for me, thanks....  Took almost 5 hours to do Kates thermostat at Timbucs the other month.   Transfer pipe was as stuck as a stuck thing and had to be broken out.....
« Last Edit: 29 March 2008, 11:34:39 by hotel21 »
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #9 on: 29 March 2008, 11:37:34 »
LMAO not a Happy Broocie that day ;D
Martin_1962
« Reply #10 on: 29 March 2008, 11:51:14 »
I'm going to take the heads off mine to do mine!!!!!!
trebor
  • Swindon
« Reply #11 on: 29 March 2008, 12:08:16 »
I sure did after I got the damn thing off!
markey mark
  • SLady bitshorpe north lincs
« Reply #12 on: 29 March 2008, 15:51:35 »
you have to remove transfer pipe to get passenger side head off martin !! :(
Martin_1962
« Reply #13 on: 29 March 2008, 18:50:49 »
aghhhhhhhhhhhhhhhhhhhhhh!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
ScottieMV6
« Reply #14 on: 29 March 2008, 18:52:26 »
Thanks for all the advice so far. Its been a while since I got my hands dirty so i am definitely going to give it a go.
One thing - I bought the new stat from a local parts shop who I trust but you all seem to be saying that I have to replace the housing too. Is that right? Do I need to buy a new housing as well as the stat?
Thanks
