Author Topic: Flickering ECU Light  (Read 2422 times)
trebor
  • Swindon
« on: 25 March 2008, 20:12:20 »
My ECU is flickering really quickly
read the code and its 73 - MAF sensor voltage low
I reset the battery, and the light went out, but 2 miles down the road it came back on.
Double checked the connection and wiring, even taped it in place.  Reset battery and this worked for 8 miles cruising, but came back on  :(
So not sure if its the MAF sensor or the wiring
Re: Flickering ECU Light
« Reply #1 on: 25 March 2008, 20:14:59 »
Measure the battery voltage at idle and 3000rpm as a starter.
trebor
  • Swindon
« Reply #2 on: 25 March 2008, 23:49:43 »
Which pins do I test?
Mike Collins
  • North of Bristol
« Reply #3 on: 26 March 2008, 08:22:29 »
Battery terminals?
trebor
  • Swindon
« Reply #4 on: 29 March 2008, 19:39:42 »
Get 12.7v across battery - engine not running and 13.7 when engine running.
I've tried another afm but light is still flickering.
It started after doing the thermostat, not sure what I could have upset to cause this!
« Reply #5 on: 29 March 2008, 21:16:41 »
Ah, probably an air intake leak then - check the plenum o rings and the other seals you had to remove.
trebor
  • Swindon
« Reply #6 on: 30 March 2008, 00:15:55 »
can this cause the ecu light to flicker?
Albatross
  • Bedford
  • An LSD & an S2000!
« Reply #7 on: 30 March 2008, 00:18:48 »
I'd hazard a guess at yes if TB says to check it.
« Reply #8 on: 30 March 2008, 11:34:58 »
Yes, as its storing a MAF fault (hence the 73). Reason its storing MAF fault is because unmetered air is getting in engine (via airleak), and ECU knows how much air is in the engine (via lamda feedback, and amount of fuel its putting in), and this doesn't match what MAF is saying.
trebor
  • Swindon
« Reply #9 on: 30 March 2008, 14:53:59 »
I think I've located the problem to the breather box thing on top of the engine.  Underneath theres a round bit that is meant to slot into a corresponding hole in the plenum...but its not a tight fit and air is being sucked in here.
Should there be a rubber seal that goes round the protruding bit of the breather box?
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #10 on: 30 March 2008, 15:06:14 »
Yup but I doubt you can get a replacement from Vx.  Try B&Q or a plumbing outlet
trebor
  • Swindon
« Reply #11 on: 30 March 2008, 15:28:42 »
its definitely missing a seal.
markey mark
  • SLady bitshorpe north lincs
« Reply #12 on: 30 March 2008, 15:50:41 »
you can get them from vauxhall mate only a couple of quid :y
Page created in 0.011 seconds with 22 queries.
