Author Topic: Window wont go up  (Read 2298 times)
bighed
  • Shropshire
Window wont go up
« on: 29 March 2008, 21:09:09 »
In the pouring rain I accidentally put drivers side rear window down instead of my own. Now, when I close it, it goes 3 parts of the way up then comes back down. >:( Got proper wet!!  :'( Had to keep tapping up to get it to go up all the way. Any ideas as im baffled.  :-[
Albatross
  • Bedford
  • An LSD & an S2000!
Re: Window wont go up
« Reply #1 on: 29 March 2008, 21:21:52 »
dab until it is closed all the way then hold the button for at least 5 seconds so that you're "forcing" it up. It should re-"learn" where the top of the window frame is.
« Last Edit: 29 March 2008, 21:22:19 by Albatross »
« Reply #2 on: 29 March 2008, 21:33:54 »
The window is coming back down cos the window is too tight in the guides & it thinks there's something/one trapped in the window. Lub the guides with silcon spray.
The reset by holding the button in the up just resets this feature after the power has been off.
bighed
  • Shropshire
« Reply #3 on: 29 March 2008, 21:37:20 »
Think most vauxhalls have this feature dont they?? My astra has got it.
Thanks both will try resetting it first then the silicone spray  :y :y
« Last Edit: 29 March 2008, 21:37:43 by bighed »
bighed
  • Shropshire
« Reply #4 on: 29 March 2008, 21:44:31 »
Just tried reseting it and it hasnt worked. there doesnt seem to be any friction as it goes up to cause it to come back down??
Albatross
  • Bedford
« Reply #5 on: 29 March 2008, 21:47:13 »
I have had exactly the same problem on my rear off-side door for the last month and no (discernible sign of) friction either. I'll just pop out and try some silicone spray now and see if it sorts it and let you know. :y
Albatross
  • Bedford
« Reply #6 on: 29 March 2008, 21:56:16 »
Nope, no joy :(
There is absolutely no friction at the door to make this happen (I have also now given it a good smear of silicone spray too) and what's more if you dab until after this point the window will then auto-close to the top and not bounce off the top of the door, so it doesn't appear to need to re-learn the height of the door either.
We have the same problem.
bighed
  • Shropshire
« Reply #7 on: 29 March 2008, 22:11:45 »
Anybody got any ideas to help me n Albatross?? Were desperate now  :y ;D
« Last Edit: 29 March 2008, 22:12:21 by bighed »
bighed
  • Shropshire
« Reply #8 on: 30 March 2008, 00:50:14 »
Have tried spray myself now and still no luck.  >:(
Danny
  • Wigan, Greater Manchester
« Reply #9 on: 30 March 2008, 03:50:36 »
there will be something there for definate that's causing the safety feature to kick in
Cav9_4
  • Sutton-In-Ashfield,Notts
  • 2003 Omega 2.6 Elite
« Reply #10 on: 30 March 2008, 04:15:22 »
Are your windows rising square?,iv'e known it for the guides to come loose or rubbers split,not on Omega's though,just a thought..
zywiec
  • Cambridge
« Reply #11 on: 30 March 2008, 10:30:21 »
it could be the internal mechanisem of the window try taking off the door card and having a look might need some new bushes or just lubbing inside.
I got the same problem put it down to that but cant be bothered to take off the door card as i dont have kids and no one really sits in the back that often.
Albatross
  • Bedford
« Reply #12 on: 30 March 2008, 14:23:02 »
How do you start to remove the rear door card on a face-lift?
zywiec
  • Cambridge
« Reply #13 on: 30 March 2008, 18:32:09 »
theres a good guide in the maint section not sure which door its for but pretty sure they cant be that diffrent. had both my front ones offand it wasa doddle just be carefull of the plastic strip at the top as i snapped mine and it was a pita getting it glued back together.
