Author Topic: Strange  (Read 1041 times)
paulmcclung
  • Falkirk
Strange
« on: 31 March 2008, 19:41:39 »
Ok on the way home today my indicators stopped working for some reason. They were doing nothing at all. So having recieved a cheapo tech 2 the other day I plugged it in. I got error 31 and 73 now I know that 31 is to be expected as engine not running but what is this 73 Mass Air Flow Sensor Voltage Low all about. The indicators started working again after it was on the diagnostics for some reason???
Dazzler
  • Haverhill, Suffolk
Re: Strange
« Reply #1 on: 31 March 2008, 20:13:27 »
Indicators might be a dodgey fuse or relay which are in the area you plugged your gadget into.
Humpy
  • Tunbridge Wells, Kent
Re: Strange
« Reply #2 on: 31 March 2008, 20:15:18 »
Normally it's a dodgy Hazard Warning Light switch that causes the Indicators to pack up! Give it a wiggle and you'll probably find they'll work again. When you drive on the atrocious roads that we have in Tunbridge Wells you have to do this quite often >:( I've even had switches fall out the dashboard going over some bumps :o
Humpy
