Author Topic: White oil filler neck  (Read 1410 times)
vomegaowner
  • Bognor Regis
« on: 31 March 2008, 19:01:40 »
Hi im after some advice on why there is white residue in filler neck and on under side of cap? i do not susspect any head gaskets leaking as coolent is ok the dip stick in ok with golden oil i just dont get it?
I have not dun any journeys in it apart from a 3mile run from where i bought it from.
Why does the sound of a V6 make your right foot heavyer?
Re: White oil filler neck
« Reply #1 on: 31 March 2008, 19:07:19 »
Its nothing to worry about, its caused by condensation due to short journeys, the next time you do an oil change try Vauxhalls own oil, it seems to be less prone to happen :y
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #2 on: 31 March 2008, 19:11:44 »
What oil are you using?  Genuine Vauxhall oil tends to make this condition less evident...
DC
Edit " Pete beat me to it I see...  same thoughts however!" :y
« Last Edit: 31 March 2008, 19:13:43 by dave_c »
tomoco
  • leicester
« Reply #3 on: 31 March 2008, 20:43:49 »
Agree: Been doing some short journeys myself and you guessed it (oil filler a bit scummy). Went to skegness at the weekend (about 90 miles) when i checked the filler cap on both journeys (Clean as a whistle)
You worry to much mate :y :y
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
« Reply #4 on: 31 March 2008, 21:29:04 »
I'd be concerned if it was clean when you left the place you bought it from and 3 miles later you have mayo on the cap.
Is it as bad as my wifes.....
hotel21
  • The Kingdom of Fife
« Reply #5 on: 31 March 2008, 23:46:13 »
Clean off as much as possible and have a couple of decent runs in the car and see if it reuturns....
As already said, short journeys and less than good oil is the main culprit....   ;)
