Author Topic: Central Locking problem  (Read 1367 times)
steps2914
« on: 30 March 2008, 16:53:43 »
Hi
When using the remote key to lock the car (door is shut), the door will lock and then re-open as if the car thinks the door is not shut. Has anyone had this problem.
I have replaced the solenoid as this stopped working and this now seems ok.
« Last Edit: 30 March 2008, 16:55:22 by steps2914 »
Matchless
  • Nottingham
    • A white van
Re: Central Locking problem
« Reply #1 on: 31 March 2008, 10:39:16 »
One of your lock motors is not working properly, the system drives all the motors to lock then checks for 'locked' indication from micro switches inside of the motors. If one motor isnt moving or travelling far enough (or is a bit slow) then the system unlocks again.
Most likely cause is a faulty motor (actually one of the switches inside it) but check all five and try lube on any sticky ones.
vomegaowner
  • Bognor Regis
« Reply #2 on: 31 March 2008, 18:57:16 »
I had this problem as i have only just got this car and it had sat for a while all i did was spray wd40 everywhere all over door mechs ect...
and this sorted it no problem.
Why does the sound of a V6 make your right foot heavyer?
steps2914
« Reply #3 on: 02 April 2008, 10:40:54 »
Thanks for your comment - fault intermittent still chasing
