Author Topic: Breather box kaputt??  (Read 1228 times)
Bacon Butty Man
  • Cleveleys Nr Blackpool
  • now own a Laguna 2
« on: 02 April 2008, 11:25:09 »
ok, felt adventurouse today, thought i would clean my breather box out, tokk it of nicely, got loads of crud out but one of the breathers is blocked, its been soaked in carb cleaner, gunk, even paraffin, nothing will shift it, blown thru with compressed air, zilch, what probs will this cause, its pipe 3.
car runs smoothly enough but is there any underlying probs if i leave it or am i better replacing it.
cheers ;D  great work thru by the way, i know its not to technical but to an ex butcher now pen pusher its a big step for buttyman kind
« Last Edit: 02 April 2008, 11:45:32 by baconbuttyman »
my Rover 75 Club SE
newhouse
  • Solihull
  • Life is all about winning small victories...
Re: Breather box kaputt??
« Reply #1 on: 02 April 2008, 11:35:04 »
I had exactly the same problem –Just finished clearing out the crud.
I used a small watchmaker’s screwdriver to bore out the solid crude in the two very small holes in the bit the plugs into the plenum shown on your diagram. Then used a garden hose to blast the whole unit out.
When you reassemble, remember to put a little Vaseline on the rubber rings on two pipes that plug into the throttle body and saddle valve that fits the hole in the top of the plenum. Stops them splitting…
Bacon Butty Man
« Reply #2 on: 02 April 2008, 11:47:33 »
will that get into the holes enough to clear it out, mind you it cant hurt to try, a little wary os blasting water thru it tho
my Rover 75 Club SE
« Reply #3 on: 02 April 2008, 12:10:25 »
Yes, the cavity behind the drillings is quite big.....so clear teh holes out and then blast through with compressed air.....ideally applying the air line ot the small hole so it throws the crudd out the back.
« Reply #4 on: 02 April 2008, 13:39:18 »
If it really is toast, I seem to recall they are not outrageously expensive - a few tens of £
