Author Topic: Dual ram sytem  (Read 4436 times)
Steve1077
Dual ram sytem
« on: 31 March 2008, 19:57:21 »
I've read about the dual ram air system on the V6 and I have a rough idea how it works, I just checked the operation of the front multi-ram actuator and it opens and stays open until I stop revving the engine, then I checked the one at the back and it opens but shuts immediately even if I hold the revs, the question is should the rear actuator stay open like the one at the front? I was only checking it as the guy that fitted my cam belt broke the front vacuum reservoir pipe off, I’ve glued it back on and have a new one on order, but I know the rear actuator has never stayed open.
Thanks
Re: Dual ram sytem
« Reply #1 on: 31 March 2008, 21:03:40 »
Thanks
Sounds OK.
And its a Multiram on V6, Dual Ram is that contraption fitted to the straight 6 fitted to rustbuckets Senators/Carltons
Steve1077
Re: Dual ram sytem
« Reply #2 on: 31 March 2008, 22:23:32 »
DOH! I did have a 24 valve Senator, lol, it was so much faster than the Omega, but thats another story, maybe it was because of all the rust, lol, only half the weight it should be.
Well thanks for the reply, I just spent the last hour checking everything and moving bits around, the actuator at the back doesn't always move when I rev it, seems to move when it wants to, and as I said when it does move its only for a second, does that change under load or something? I have to say it was like a slug with the pipe broken, seems better now
Re: Dual ram sytem
« Reply #3 on: 31 March 2008, 22:27:02 »
I remain unconvinced - it may have seemed faster due to its naff power delivery...
Humpy
  • Tunbridge Wells, Kent
Re: Dual ram sytem
« Reply #4 on: 31 March 2008, 22:34:13 »
My Monza's definately quicker than my Estate ;) Or perhaps it just seems that way? S'funny 'cos I let a mate have a go in the Meega and I sat in the back (just to see what it was like you understand) and it felt like it went like the clappers ;D It's all relative I suppose.
Humpy
Re: Dual ram sytem
« Reply #5 on: 31 March 2008, 22:34:26 »
The Omega gives a much smoother delivery, and IS prob faster but.
No Omega put the smile on my face that the Senny did, it was very enjoyable to drive. That 4k surge made the smile even more!
Multi-rams just make it boooooring (from a sensation & enjoyment point of view) gets you there faster, but not as fun  ;)
Omegatoy
  • UK
Re: Dual ram sytem
« Reply #6 on: 31 March 2008, 22:44:14 »
out where it counts on the racetrack there hasnt yet been an omega thats quicer than any of the ssixs!!! sorry guys
The Barge Captain
Re: Dual ram sytem
« Reply #7 on: 31 March 2008, 23:31:21 »
If you can see the rear ram opening breifly when reving the engine, all is ok as it is vacuum load dependant.  With the engine off load i.e on the drive the required vacuum load is only there breifly not like it would be if you had you boot on the floorboards when driving.
Galahad
  • Bath
    • 2000 Omega 2.2 GLS
Re: Dual ram sytem
« Reply #8 on: 01 April 2008, 09:46:01 »
I've had many a Senator and Omega, and much as i love the Omega (reliable old bus), the 3.0 24v Senators I have had have been quicker than any of my Omegas, though I've never owned a 3.2.
    • 530D M Sport, 330i Coupe
Re: Dual ram sytem
« Reply #9 on: 01 April 2008, 12:55:23 »
I think the multiram setup on the omega is far smoother that the dualram of the S6 Senators and Carltons (also 2.0 Vectra's had an implementation called VIM or Variable intake manifold).
Because of the smoothness of the multiram the acceleration seems pretty straight throughout whereas the Dual and Variable setups have distinct points when the rams actuate and the difference is felt.
Marks post - http://www.omegaowners.com/forum/YaBB.pl?num=1153840176 - explains how this smoothness is achieved with four modes of operation.
Perhaps a Straight 6 - V6 Santa Pod event is in order! Though I think the overall difference would be minimal, there are other factors such as weight, gearbox and diff that would make a bigger difference.
I'll get my coat now.
Squatch
  • Belfast
Re: Dual ram sytem
« Reply #10 on: 01 April 2008, 13:10:15 »
I have not had the pleasure of driving a Senator sadly :'( but I imagine it would probably accelerate faster up to 60 than an Omega which is a heavy beast! However an Omega has excellent drag co-efficient and gets better the faster it goes ;) so I reckon it would even things up at the top end!
Re: Dual ram sytem
« Reply #11 on: 01 April 2008, 13:49:01 »
Senator and Omega are the same weight give or take a few Kg.
It's probably better distributed on an Omega given that most of the engine on the Senator is ahead of the front wheels.
Whilst a big step in the torque curve makes a car feel fast it's the area under the curve and the ability of the gearbox to let you use it that matters against the clock.
Re: Dual ram sytem
« Reply #12 on: 01 April 2008, 13:50:22 »
and the Omega will be faster through the wiggly bits thanks to a better weight distribution.
Re: Dual ram sytem
« Reply #13 on: 01 April 2008, 19:13:12 »
Forgetting your race prepped senny, be interesting to put a senny up against an omega - I think you'll find little in it, perhaps Omega just having the edge.  Handling wise I guess its what you prefer - Senny a bit tail happy, Omega less so.
Would be interesting...
Re: Dual ram sytem
« Reply #14 on: 01 April 2008, 19:42:58 »
i thought the same thingwhile reading the thread last night,abs contacts maybe interested ? :)
