Author Topic: UP DATE ON misfire  (Read 2405 times)
caolan_p
  • IRELAND
UP DATE ON misfire
« on: 01 April 2008, 18:13:13 »
Hi all, im now a happy bunny, i got a brand new coil dic pack and the migg is going great i got it for £61 in belfast .  A few weeks ago there was oil in the plugs witch fried the old coil pack this led to a misfire in cyl 1 and the car going very rough .So a big thanks to all on the OOF :y :y :y :y
« Last Edit: 02 April 2008, 14:49:08 by caolan_p »
arthill
  • Greenock
  • HI all pleased to join Forum
Re: misfire
« Reply #1 on: 01 April 2008, 18:47:00 »
Hi
are you sure about that code as can't see that one listed.
  John
John
caolan_p
  • IRELAND
Re: misfire
« Reply #2 on: 01 April 2008, 19:01:04 »
Hi
  John
yes that is the one that came up on it
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Re: misfire
« Reply #3 on: 01 April 2008, 19:03:54 »
Hello all, im still getting a misfire as the code p301 showed misfire in cyl 1 ,can some one let me know if i should get a new coil pack ??? thanks
This sounds familiar (it happened to me) same symptoms anyway but not that code, you may want to check that code first................
http://www.omegaowners.com/forum/YaBB.pl?num=1197277610
Check the plug wells for oil or water as it sounds like the cam cover gasket is probably leaking oil. If so you will need to clean the breathers first as they get blocked and pressurise the cam cover which forces oil past the gasket.......see maint guide............
http://www.omegaowners.com/forum/YaBB.pl?num=1162397695
You might need new plugs if the oil has fried them.........
http://www.omegaowners.com/forum/YaBB.pl?num=1157117391
Get a genuine Vx gaket and o rings as the cheap pattern ones don't last very long. Oh and don't forget the black sealant when you are at the Vx dealer. HTH  :y
« Last Edit: 01 April 2008, 19:05:32 by alexandjen »
Trade club card holder
Code scanner available
caolan_p
  • IRELAND
Re: misfire
« Reply #4 on: 01 April 2008, 19:10:03 »
that was all done last month and put 4 new plugs in on monday .the guy that put the computer on it give me that code as i seen it to ,it was not a tec2 thou
caolan_p
  • IRELAND
Re: UP DATE ON misfire
« Reply #5 on: 02 April 2008, 14:50:27 »
THE CAR IS GOING GREAT NOW  :y :y :y
alexandjen
  • The Silver Surfer
« Reply #6 on: 02 April 2008, 17:09:10 »
What did you do?
Big_Roger
  • Southampton
« Reply #7 on: 02 April 2008, 17:13:44 »
Hi,
Code P0301 Missfire cyl 1
Roger
Be patient ! Something else will go wrong for you to fix if you wait long enough !!
caolan_p
  • IRELAND
« Reply #8 on: 02 April 2008, 18:41:17 »
What did you do?
got a new coil pack  :y
caolan_p
  • IRELAND
« Reply #9 on: 02 April 2008, 18:46:05 »
Hi,
Roger
thanks  :y
alexandjen
  • The Silver Surfer
« Reply #10 on: 02 April 2008, 18:49:12 »
What did you do?
:y :y
£80ish?
caolan_p
  • IRELAND
« Reply #11 on: 02 April 2008, 18:57:29 »
What did you do?
:y :y
£80ish?
£61 it was the cheapest i could get so i jumped at it  :y
