Author Topic: Driving along and.....  (Read 12118 times)
zippo
  • manchester
Re: Driving along and.....
« Reply #15 on: 30 March 2008, 09:08:32 »
15-15A Reverse lamps, cigarette lighter, glove compartment lamp,automatic transmission, automatic level control system, cruise control, ventilation for rear door windows, position memory for seat and mirror adjustment
Ciggy light would be my first port of call. 5p's fit nicely!  ;D  ;D
 the car has never had a cig lighter while Ive owned it , but i took it all out anyway and the fuse still blew. But everything the fuse is meant to protect still works apart from the instruments themselves i.e  fuel /temp gauge .The only warning light i do have that works, is for the battery Ah well the joys of motoring  :D
zippo
  • manchester
« Reply #16 on: 31 March 2008, 11:03:17 »
the wife has called in at a former dealers to see if they could shed any light on the problem ( iam house bound for a bit) .Mrs Zippo has just been charged £64.63 for tech 2 and been told the car needs a new battery and alternator , 10-15 minuets work £65 quid robbing git
« Reply #17 on: 31 March 2008, 11:08:26 »
Sounds dodgy to me. Neither battery nor alternator would cuase the symptims. They have seen the battery light and jumped to the first conclusion they could.
First job is to find the reason the fuse blows and fix that. I suspect there'sd nothing wrong with the battery and alternator. The battery light is on because its' supply fuse has blown!
zippo
  • manchester
« Reply #18 on: 31 March 2008, 11:13:07 »
would the tech 2 not pick up the blown fuse
« Reply #19 on: 31 March 2008, 11:30:21 »
No. I wouldn't say the Tech 2 would be as much use as a multimeter in this instance. If a fuse keeps blowing the reason needs to be identified first, and only once that's fixed should any further diagnosis be carried out, if necessary.
As I said, I believe the reason for the battery light on, is that the supply to the dash has failed, and this is confirmed by the fact that the fuse has blown.
The garage were wrong to charge you for a Tech 2 session, IMHO, because that was never going to help them find a short circuit.
zippo
  • manchester
« Reply #20 on: 31 March 2008, 13:44:19 »
well that's an auto electrician baffled ,he's totally stumped as to what the problem is
      I FEEL A NIGHTMARE COMEING ON
« Reply #21 on: 31 March 2008, 13:48:41 »
One step back to start with.
Has anything been disturbed, removed, installed recently?
zippo
  • manchester
« Reply #22 on: 31 March 2008, 15:31:01 »
no Mark, not a thing
zippo
  • manchester
« Reply #23 on: 31 March 2008, 22:15:04 »
the garage sort of admitted that they might not have investigated the problem properly and want to see the car again ,which they will if the sparky doesn't come back  ::)
« Reply #24 on: 31 March 2008, 22:22:34 »
Well the next stage is to unplug the ancillaries one by one to narrow it down further inspecting the wiring around them as you go.
« Reply #25 on: 31 March 2008, 22:26:15 »
This fuse actulay powers:
15-20A Reverse lamps, glove compartment lamp, automatic level control system, cruise control, seat and mirror adjustment, radio, heated rear seats, sun roof, instrument illumination, window operation, cooling fan, headlamp range adjustment
So check the reverse light bulbs, glove box bulb etc as they are easy to do.
zippo
  • manchester
« Reply #26 on: 01 April 2008, 09:03:45 »
morning Mark ,even with the fuse blown the reversing lights glove box lights still work .The only symptoms are the battery light permanently on and no warning lights/rev counter fuel/temp gauge not working
« Reply #27 on: 01 April 2008, 09:09:21 »
What year and I will pull up the specific circuit diagram.
zippo
  • manchester
« Reply #28 on: 01 April 2008, 09:20:26 »
it was registered January 01
« Reply #29 on: 01 April 2008, 09:23:04 »
Is it DEFINATLEY F15 blowing becasue that powers loads of stuff....
Do the wipers operate (looks like it would only affect the rain sensors)
Does the backlight in the headlight switch operate?
Does the engine store/indicate a fault?
Rad fans operating?
Mid operational?
The favourite place to check would be in the engine bay around the ecu box
I guess yours is an auto and hence why the reverse lights are not affected.
« Last Edit: 01 April 2008, 09:25:24 by Mark »
Pages: 1 [2] 3 4  All   Go Up
