Author Topic: Oil leak  (Read 3956 times)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Oil leak
« Reply #15 on: 28 March 2008, 23:37:03 »
How difficult are these to do? Are they expensive? How do I search a topic??
Done mine today, took about 2 hours and cost £63 with TC (saves about £10).. for the £63 you get the four Cam Cover Gaskets, 16 "O" rings and a tube of black sealer :y
Re: Oil leak
« Reply #16 on: 28 March 2008, 23:43:50 »
Probably did .. but you've done it before I guess !!
When I did mine took nearly a full day, as I carefully read each printed guide and did things very slowly. I had problems with the cable tray and cut a corner .. bad news .. that side didn't go on properly and leaked like a sieve. In here that night asking questions .. got good advice ... redid the job the next day in half the time.
So if you know what you are doing ( I don't half the time!!) it probably is a couple of hours .. if you are like me .. don't rush and allow plenty of time. It is NOT difficult as I found ... I made my own problems !!!
I'll be doing the new beast as soon as the weather improves, and I'm far more confident now.
bighed
  • Shropshire
Re: Oil leak
« Reply #17 on: 28 March 2008, 23:53:25 »
Brilliant guys. Well gonna have a decent look tomorrow and will let you know how i get on.  :y
CyNick
  • Monmouthshire
  • Car is stuck in KIDDERMINSTER!!
Re: Oil leak
« Reply #18 on: 29 March 2008, 01:16:35 »
I've got to do mine too..
.. let me know how you get on?  'cos I've not attempted anything like this before - and I'll be pleased to hear if it's possible to do without having been shown how to do it (properly!!  :))
bighed
  • Shropshire
Re: Oil leak
« Reply #19 on: 29 March 2008, 02:50:56 »
Yeah will do. Gonna see if I can get better idea of where its comin from as it was raining at the time of looking. Axel stands FTW. :y :)
bighed
  • Shropshire
Re: Oil leak
« Reply #20 on: 29 March 2008, 15:34:14 »
Pah Raining again but just been under car and can confirm that it is the cam cover gaskets leaking. Not suprising really when the previous owner had overfilled her with oil.  >:( >:( >:(
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Oil leak
« Reply #21 on: 29 March 2008, 15:39:03 »
When you do your Cam Covers mate make sure you clean the breathers out aswell:y
bighed
  • Shropshire
Re: Oil leak
« Reply #22 on: 29 March 2008, 15:48:53 »
Will do, thanks. Is there a particular way of doing this?
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Oil leak
« Reply #23 on: 29 March 2008, 15:55:48 »
Have a read of this mate it should help :y
http://www.omegaowners.com/forum/YaBB.pl?num=1152598350
Big_Roger
  • Southampton
Re: Oil leak
« Reply #24 on: 29 March 2008, 17:37:02 »
Hi,
It's also a good time to change your spark plugs as well, while everything is out of the way.
Roger
Be patient ! Something else will go wrong for you to fix if you wait long enough !!
bighed
  • Shropshire
Re: Oil leak
« Reply #25 on: 30 March 2008, 00:00:58 »
Thanks roger. Been told that before  :y
biggin_boy
  • Hampshire
Re: Oil leak
« Reply #26 on: 04 April 2008, 21:58:44 »
i did my cam cover gaskets following the guide it took me about 5 hours.
but the guide is spot on
but mine is now again leaking (i made the mistake of non vx gaskets) so i am converting to vectra covers as i have been told these are better? and genuine vx gaskets this time
snap-on scanner up to 2002 all makes hampshire area
Re: Oil leak
« Reply #27 on: 04 April 2008, 22:02:52 »
if you convert to vectra covers the pressure will find the next weakest point to escape from,which iirc is crank oil seals.
