Author Topic: Ignition switch help please  (Read 1523 times)
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
« on: 05 April 2008, 18:32:06 »
Last night disaster struck , the ignition switch packed up on my car . The key went in ok the lights all came on, on the dash  but the key had no spring back from engine start position . So I knew the contact block had failed .  Called out the AA but they could only send out an agent not a proper patrol  >:( When he eventualy turned up nearly two hours later I told him what the problem was and how to  get around it and that I just could not get the thing apart . I could not remember  how to get the terminal block off the back of the switch . I explained it again to him and told him what I needed . only to be told I was wrong and that the wiring was part of the switch and it all had to be removed from up under the dash  :o HE TOLD ME HE USED TO WORK FOR VX so he knew what he was talking about  ::) any after persuding him I knew what  I
LFF64
  • HADDENHAM BUCKS
Re: Ignition switch help please
« Reply #1 on: 05 April 2008, 18:38:21 »
was doing I  borrowed a big screw driver and removed the damged contact block   ;) I managed to get the car going by hot wiring it something he could not do  :o and get the car home . question is anyone any idea how much the contact block part of the switch costs and is it worth trying one from the scrap yard I would assume most of the vx cars would be similar if not the same
« Reply #2 on: 05 April 2008, 18:40:38 »
Its not easy, you have to insert a screwdriver into the centre of the terminal block to release a catch that allows it to be removed.
LFF64
  • HADDENHAM BUCKS
« Reply #3 on: 05 April 2008, 18:46:08 »
Sorry it is off now but need a new contact block have you any idea how much they are
« Reply #4 on: 05 April 2008, 18:48:53 »
Not as much as you would think, under 20 quid from memory.
LFF64
  • HADDENHAM BUCKS
« Reply #6 on: 05 April 2008, 19:00:10 »
Brilliant thanks for that is it worth mentioning OOF to them  :question
Dazzler
  • Haverhill, Suffolk
« Reply #7 on: 05 April 2008, 19:04:00 »
Always worth it ;)
« Reply #8 on: 05 April 2008, 21:31:28 »
..... only to be told I was wrong and that the wiring was part of the switch and it all had to be removed from up under the dash  :o HE TOLD ME HE USED TO WORK FOR VX so he knew what he was talking about  ::) any after persuding him I knew what  I
It must've been a long while back. The switch was part of the wiring on my Manta.
