Author Topic: satnav vauxall omega elite 3.2  (Read 2311 times)
ron
  • chelsea sw35bl
« on: 04 April 2008, 08:18:30 »
how can i check satnav cable there is a wire connected to my tax disk is  inthis the satnav ariel on the left hand side of car does that mean all the wiring is on the left kick down side ps. gps red so need to check cable what colour is cable thanks in advance
    • 530D M Sport, 330i Coupe
Re: satnav vauxall omega elite 3.2
« Reply #1 on: 04 April 2008, 09:49:20 »
Tax disc antenna is for a 3rd party phone kit.
Sat nav aerial is the base part of the roof antenna.
All the wiring for the roof antenna runs down the right hand side of the car.
ron
  • chelsea sw35bl
« Reply #2 on: 04 April 2008, 09:58:49 »
thanks does that mean its combined with ariel for the radio?what colour is satnav cable ?
« Reply #3 on: 04 April 2008, 11:09:36 »
Check the connection behind head unit - its the smaller of the 2 aerial connections.  In particular, pay attention to cage being distorted, as this causes poor connection.
ron
  • chelsea sw35bl
« Reply #4 on: 04 April 2008, 13:42:29 »
is anybody near to the london area who could do it for me i will give them something for doing it just correcting my gps signal ?so it goes green please
« Reply #5 on: 04 April 2008, 14:13:20 »
Soz, I'm nearer Brum than London...
To test if it is the cage, pop radio out, remove cage, and plug connections directly into back of stereo. I fit works then, just bend the cage a little :)
ron
  • chelsea sw35bl
« Reply #6 on: 04 April 2008, 14:18:09 »
i tried but could not do it so frightened i would screw everything up
« Reply #7 on: 04 April 2008, 14:29:19 »
Which bit, removing radio, or removing cage?
If radio, you have removed the grub screws and are using proper radio removal keys (as opposed to just trying to pry it out, which will break it)?
ron
  • chelsea sw35bl
« Reply #8 on: 04 April 2008, 15:10:25 »
removed grub screws do i need radio removal keys
« Reply #9 on: 04 April 2008, 15:12:49 »
Yup, need a set of double din removal keys (Halfords, £4).  Possible to do with nails etc, but I'd recommend using the proper keys ;)
ron
  • chelsea sw35bl
« Reply #10 on: 04 April 2008, 15:16:32 »
does the whole piece come out or just the radio part thanks anyway
« Reply #11 on: 04 April 2008, 15:19:38 »
The entire radio comes out - the 7" x 4" (and about 7" deep) bit.  Removal keys go in the corners of the bin that comes out.
Hope that makes sense?
If you are that concerned about doing it, if ever you pass my way (nr Jnc 10 of M40, or 15mins from Jnc15a or M1), I will gladly have a look at it for you...
ron
  • chelsea sw35bl
« Reply #12 on: 05 April 2008, 13:49:39 »
hi all just an update took out radio jiggled it in cage now satnav is showing green and working thank you to all who gave good advice ron
Weds
  • Chatham, Kent
  • My other hobby
    • Mercedes E class 350 CDi
« Reply #13 on: 05 April 2008, 16:14:32 »
Come and jiggle mine to see if you can get my phone kit to work please :-)
« Reply #14 on: 06 April 2008, 10:43:45 »
Excellent news :y
