Author Topic: should the headlight switch "click"  (Read 1748 times)
keith2.2
  • Lincolnshire
« on: 08 April 2008, 21:53:58 »
is the rotary headlight switch supposed to click between positions? Mine just rotates with no sort of tactile feedback - I'm used to VAG ones clicking between functions. Is mine worn or as normal?
2.2 litre, 210bhp, 910kg stripped honda civic
LPG'd MV6 Omega
markey mark
  • SLady bitshorpe north lincs
Re: should the headlight switch "click"
« Reply #1 on: 08 April 2008, 21:56:17 »
yes kieth they do have a positve feel if not broken !! the clips on side hold small ball bearings in the side  :y have a spare here £10 if you want it :y
rickyboy
  • Glasgow
« Reply #2 on: 08 April 2008, 21:57:25 »
Should click, I've bu**ered mine as well.  I passed an MOT without it clicking so I wouldn't worry about it.
« Reply #3 on: 08 April 2008, 21:57:27 »
Yes, classic signs that its been removed and somebody has popped the retaining springs out and lost the spring and ball bearing!
keith2.2
  • Lincolnshire
« Reply #4 on: 08 April 2008, 22:25:21 »
I suspected it might have been removed because I found a bulb that I recognised as being from the switch unit from a thread on here. It also doesn't illuminate the foglight switches. Not a prob yet as I've not driven in any fog!
LPG'd MV6 Omega
« Reply #5 on: 08 April 2008, 22:29:41 »
Possible someone has tried to chav it with blue LEDs at some point :P
markey mark
« Reply #6 on: 08 April 2008, 22:46:20 »
