Author Topic: Timing belt kit...  (Read 3580 times)
SweetOmega
  • Morden, Surrey.
Timing belt kit...
« on: 08 April 2008, 22:10:04 »
Hi all,
I need to change my timing belt and ordered the kit from Autovax.  Arrived this morning and its a SKF NT05001 (VKMA 05500).  I guess it is the correct item for my car and matches the eng no: range.
Is SKF original equipment part(s) ? Is this OK to use?
Looking for guidance...
.....By the way bought the the Cambelt CD too. Its brilliant !!!
Can the cameraman share the details of the Camcorder used to film please? It is so clear...need to replace my 9 year old JVC.
SweetOmega
  • Morden, Surrey.
Re: Timing belt kit...
« Reply #1 on: 09 April 2008, 10:27:59 »
Any feedback will be very much appreciated.
shyboy
  • Southport, merseyside.
    • Mazda 6
« Reply #2 on: 09 April 2008, 10:43:12 »
Hi all,
PM member Robin Hood who produced it.
Can't help with SKF gear, but someone will shortly, I'm sure.
« Reply #3 on: 09 April 2008, 10:43:14 »
I have fitted one of these myself. SKF are a respected manufacturer of bearings so the pulleys should be OK and I believe this kit has a Gates belt which will also be fine, with the added bonus that it's got markings on. :y
SweetOmega
  • Morden, Surrey.
« Reply #4 on: 09 April 2008, 10:53:10 »
Many thanks Kevin. I feel more relaxed now as this was bugging me whether Autovax had supplied the corrrect kit.
Cheers.
« Reply #5 on: 09 April 2008, 11:29:12 »
Cheers.
I should have added that there are still variations with model year. I supplied engine numbers when I ordered and they got the right kit (the one that was previously on the car was wrong!).
Just have a careful look at the cast plate that holds the two upper tensioners to make sure it is the same, and also check that the lower tensioner is adjustable if the current one is (later cars have a fixed idler here, mounted about 1/2 way up the belt run. earlier cars with the idler just under the water pump have an adjustable one.)
Robin Hood
  • Nottingham
« Reply #6 on: 09 April 2008, 11:37:22 »
The video camera used was a Sony TRV900E and is also around 9 years old.   ;)
Hadn’t used it in a while so set everything to auto hence Mark’s white gloves bouncing the exposure about a bit.   ;D
« Reply #7 on: 09 April 2008, 11:42:29 »
The genuine kits also use SKF bearings....as do the gates and Contitech kist to.
Dazzler
  • Haverhill, Suffolk
« Reply #8 on: 09 April 2008, 13:48:56 »
Rightly or wrongly i have found that the adjustable pulley is identical in size to the non adjustable one, so i have fitted the adjustable one to the later engines which makes life so much easier for bank adjusting ;)
« Reply #9 on: 09 April 2008, 14:18:55 »
I've done several engines with the non-adjustable idler and the nearside bank has timed perfectly every time [size=8]or been a tooth out[/size].
I guess this is why it was deemed surplus to requirements. Depends what method you're used to using I guess. There's probably no harm in having an adjustable idler there. :-/
Dazzler
« Reply #10 on: 09 April 2008, 14:22:56 »
The SKF kit i brought one had the adjustable one so i stuck it on and have done so ever since ;)
SweetOmega
  • Morden, Surrey.
« Reply #11 on: 09 April 2008, 21:52:14 »
Dear all,
Many thanks for all the valuable feedback / response.
It is very comforting and gives me warmth feeling to learn that you all are sharing your experience with the only goal to help a fellow OOF member.
The best Forum ever !!!   :y
robbo299
  • luton, beds
« Reply #12 on: 09 April 2008, 22:03:06 »
Hi All,  As i have worked for SKF man and boy for 37 years its nice to hear we are held in high regard. I could " have a word" and see if there is any chance of a discount for the cambelt kit. I have managed to get wheel bearings and even hub assemblies in the past for my own and friends cars. Even if i can get them for what we call manufacturers price this may well be a lot cheaper than one from suppliers with their mark up. I will make enquiries and post a reply as soon as i can. :y
             Robbo.
« Reply #13 on: 09 April 2008, 22:18:56 »
             Robbo.
I'm sure that would be much appreciated. :y
Should be able to get a decent sized order together next time there's a cam belt party.
robbo299
  • luton, beds
« Reply #14 on: 09 April 2008, 22:34:23 »
Hi Kevin, You seem to be on the same wavelength as me regarding seeing if i can get some kits for a cambelt party. lol. Don't know what VX charge for them but sure, if i can, i will be able to get them a lot cheaper. Will try and work out a sales pitch before i go into work tomorrow. ;D How many do you think will be needed  roughly? Just thought it would be good to get a rough number in case they ask. Of course this could be an on going request as well. I wasn't sure if we supplied VX with cambelt kits as a genuine VX part. I looked through my catalogue when i bought my miggy estate a few months ago to see what bearings etc i could get should i need one. Looked quite a comprehensive range. We used to supply all the motor manufacturers from Luton years ago but we went over from taper roller and ball bearing production to roller and spherical bearings and so bearings/kits we need for cars now have to be sent from central stores in Belgium. Usually takes about a week if they have them in stock so will need a few weeks notice if i can get them.
