Author Topic: HID Fog Lights  (Read 3004 times)
Re: HID Fog Lights
« Reply #15 on: 13 April 2008, 12:54:03 »
I was chatting to bro the other day about why is it most cars only have dipped beam as HIDs (the sorts of cars he is a designer for have full beam HIDs as well) - its to do with heat disipation both off the lenses (which I couldn't understand as they use less power  :-/) and the ballast packs.
Lol, not an elecronic eng is he......
The reality is that the life of a HID is not so much time limited but cycle limited i.e. they only give a certain number of on/offs.
And as you can imagine, supporting full beam results in a lot of cycles.
Hence why on some cars they use a solenoid shutter on the dip beams to support full beam using HID's on the same bulb.
The bubs themselves run at MUCH lower temperature so cant see heat being an issue.
LOL, no, he's definately not.
He did say something about they have to run all the time, as HIDs have a 0.75s turn-on time (hence no good for full beam), using shutters as you say (in addition to a seperate dipped HID on the last design they did).
He did say that cooling the lights was a challenge - mind you, a bloody great 5.5l supercharged lump producing 600+ bhp under the bonnet isn't going to keep anything cool :o - prototype testing proved the headlights were overheating.
Re: HID Fog Lights
« Reply #16 on: 13 April 2008, 12:57:08 »
Well they will be worse with a halogen one!
Re: HID Fog Lights
« Reply #17 on: 13 April 2008, 13:02:28 »
I'll need to ask him whether it was bulb or ballast related, or if there were other factors - it was one of those 'by the way' conversations when I was explaining I didn't like the yellow full beam and white dipped beam on my Omega...
Re: HID Fog Lights
« Reply #18 on: 13 April 2008, 13:07:55 »
The turn on time is due to the need to strike the arc in the discharge lamp (at many KV) before settling onto the run voltage.
Ballast is hardly an excuse, you could mount that anywhere, even under the wing!
Re: HID Fog Lights
« Reply #19 on: 13 April 2008, 13:12:09 »
A bit like charging a camera flash is my simple way of looking at HIDs.  Once running, its just under 100v isn't it?
If it was ballast, mounting it in the cooling ducts etc could always be a possibility.  As said, need to ask him what the issue was, and what the solution was - may have even been specific to that car  :-/
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
Re: HID Fog Lights
« Reply #20 on: 13 April 2008, 23:21:47 »
Well I'm more than happy with the HID convertion on mine, once I get the kit for the fogs I'll post more pics and what I thought of them
