Pages: 1 [2] 3  All   Go Down
Author Topic: caravan and my mega  (Read 7867 times)
32omegalad
  • bracknell
Re: caravan and my mega
« Reply #15 on: 16 March 2008, 19:47:28 »
I know nothing about caravans but could it be that someone has put wrong size tyres on it ie larger than standard on the front axle or smaller ones on the rear axle.
good point but going on car rule ish wheel/tyre size should always be the same size all of mine are same size and brand i could put smaller alloys on it tho
davlad22
  • Sunny Yorkshire
« Reply #16 on: 16 March 2008, 19:50:08 »
235/45/17 on your elite mate
32omegalad
  • bracknell
« Reply #17 on: 16 March 2008, 19:53:53 »
yes they are mich primacys standard elite wheels. The van has michilin some thing on them and they are proper van tyres
« Reply #18 on: 16 March 2008, 19:56:08 »
What kind of towbar have you got fitted? And as mentioned before, what is the height of the towball without a 'van on the back?
32omegalad
  • bracknell
Re: 'Weekend Pikey Wagon' (Please delete all my posts
« Reply #19 on: 16 March 2008, 19:59:15 »
ground to top of ball is seventeen inches bang on
Big_Al
« Reply #20 on: 16 March 2008, 20:09:56 »
Blimey ! Just glad I ain't got a caravan !
32omegalad
  • bracknell
« Reply #21 on: 16 March 2008, 20:10:48 »
tow bar is a witter standard fit non  detachable
MickAP
  • South Derbyshire
« Reply #22 on: 16 March 2008, 20:15:12 »
Got a single axle caravan, and omega estate.
Mine too sits lower than when on my last car, your problem is obvious you need to bring the back end up on the car or change the van to a single axle. Raising the back of the car may not be advisable. I see many 4 X 4 towing twin axles,  the reason is they have the increased height for them.
Just my thoughts!
Mick
davlad22
  • Sunny Yorkshire
« Reply #23 on: 16 March 2008, 20:33:02 »
I too am not an expert but I would say your van is too big for the car? The omega is a great tow car but even they have their limits!  :-/
Tyre pressures on your van should be around 38psi as opposed to a single axle which is quoted around 60psi.
32omegalad
  • bracknell
« Reply #24 on: 16 March 2008, 20:56:18 »
Thanks people some very good points.
I went for the larger van as i take the olds away in it.I will be at the van next wk end so will try a few different things out on it and see where that goes.I hope not straight pass me on the moterway.
Thanks again will post findings
James
Martin_1962
« Reply #25 on: 16 March 2008, 21:11:36 »
Does it balance on the 4 wheels
Ideas
Inflate rears to maximum and fronts to minimum.
Contact the builder
Try the awning loaded towards the front
davlad22
  • Sunny Yorkshire
« Reply #26 on: 16 March 2008, 22:59:02 »
Good advice, they want to be fairly well pumped anyway when under load. Take the van pressures down.
A bit drastic but spare wheel out of mig into front of van?
MickAP
  • South Derbyshire
« Reply #27 on: 16 March 2008, 23:12:12 »
Don't mess with the tyre pressure on either the van or the car, remember it will be also dangerous especially if you are putting odd loads into the front of the caravan. The insurance and police will look at these very seriously if you are involved in any kind of accident, and let's hope not.
Follow the manufacturers recommendations or best still contact The Caravan Club.
You'll also find some well informed people to talk to here www.touringandtenting.com just ask.
Mick
davlad22
  • Sunny Yorkshire
« Reply #28 on: 16 March 2008, 23:24:27 »
RIGHT! I think i've found a possible solution. Has one of these been mentioned?.....
AL-KO extended neck towball
http://cgi.ebay.co.uk/AL-KO-TOW-BALL_W0QQitemZ110234302087QQihZ001QQcategoryZ33653QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I wouldn't worry about it covering your numberplate, you can always take it off and really, I don't think even our friendly UK police would be that petty!
This is another possible option?...
http://cgi.ebay.co.uk/3-or-5-drop-plate-towbar-towball-trailer-caravan-DP04_W0QQitemZ290214842205QQihZ019QQcategoryZ36632QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Though it implies it is to 'drop' the level of the towball, not to raise it, and not sure i'd trust that anyway to the size of your van.
....now you're gonna tell me you have a 'swan-neck' arrangement aren't you!
Pages: 1 [2] 3  All   Go Up
