Author Topic: swapping  (Read 4549 times)
Martin_1962
Re: swapping
« Reply #15 on: 15 April 2008, 22:23:25 »
Trust you Graham! ::)
Omegatoy
  • UK
Re: swapping
« Reply #16 on: 16 April 2008, 08:15:49 »
:( oops box died today!! got no choice but to fit the Ar 35 tomorrow now!! :o
Died of What??? what was up with it?
td engine is capped by vauxhall via ecu to save the cheapo Ar 25 they wanted to fit to cut costs,esigned to take approx 250 of torque thru it, actually it was taking  well over a third more and lasted just 97 miles before it started slipping, then 436 miles later it couldnt take it anymore!!! box is now toasted and roasted!!!!
 ;D
Omegatoy
  • UK
Re: swapping
« Reply #17 on: 16 April 2008, 08:16:58 »
 :y who me??? :o
Re: swapping
« Reply #18 on: 16 April 2008, 09:24:53 »
AR25SE!
Hope it goes well. :y
Omegatoy
  • UK
Re: swapping
« Reply #19 on: 16 April 2008, 21:17:58 »
well it went reasonably well ::)but changing an autobox on your own is not an experience i would recommend!!! box appears to be lovely and smooth now, but the damned pietzo injector lead got caught under the inlet manifold somehow  and cut through it, removed inlet again to repair the lead but im knackerd and couldnt hold the doldering iron steady enough!!!! so the engine had no power and a great big warning light on the dash :-?  but the box didnt slip!!! so am happy sort of!!! :y
Re: swapping
« Reply #20 on: 16 April 2008, 21:25:16 »
Spare needle sensor injector here ;)
Omegatoy
  • UK
Re: swapping
« Reply #21 on: 16 April 2008, 21:59:42 »
thanks bud but got to get it running before i can come over!!! un;less your passing swindon tomorrow>>?????? :y
Re: swapping
« Reply #22 on: 16 April 2008, 22:10:08 »
Not unless its on the way to Milton Keynes ;D
In Cowley very early evening on Fri if that helps?
Omegatoy
  • UK
Re: swapping
« Reply #23 on: 16 April 2008, 22:14:45 »
am actually supposed to be staying at heyford fri night  but maay not make that butwill be  :ythere saturday !!!
Re: swapping
« Reply #24 on: 16 April 2008, 22:16:38 »
Where in the Heyfords?  Might be able to drop it off if I have time.
Omegatoy
  • UK
Re: swapping
« Reply #25 on: 16 April 2008, 22:26:21 »
where you had fun changing the cambelt!!!! ;D terrys!!
Re: swapping
« Reply #26 on: 16 April 2008, 22:30:27 »
That breakign belt was a sod  >:(
I need to pop over and see Terry - need to check his vacs, so may make a trip over if I get time
Omegatoy
  • UK
Re: swapping
« Reply #27 on: 16 April 2008, 22:46:58 »
cool :y
