Author Topic: Occasional Non Start  (Read 3923 times)
VXmega
  • Dumfries
« on: 16 April 2008, 17:13:37 »
About a month ago I filled car in petrol station and when I went to start car ........... turned over fine but non start, took key out tryed again and started but felt hesitant at first but ran fine (no missfires) from then on.
It did it again last week same carry on as above, but then 2 days ago stopped car at friends garage emptyed some stuff out boot an then no start, this time I all but drained the battery trying to get it to go, we then put it on the booster and the car fired first time.
So I thought at first it was battery as it seemed to drain fairly quickly and something to do with the immobiliser.
So this morning i went into local motor factors had battery checked but it shows as fine
My friend has a cheep tech 2 and for some reason the "My Naff Code Reader" demo software, which he has used on this car before said ....... no echo or kept flashing use line 7 but wouldn't go any further....... so no fault codes obtained
The car has behaved its self all day until I parked in town and yep no start again
This time though when I let all the lights on dash do there thing ........... but I had 1 lit that is a car with a spanner through it.
Sure enough the cavalry arrive I turn the key and it fired as if nothing was wrong, cant say I saw that warning light as the car started as normal and is not on when running
I've had a look about here and as I said thought it was the immobiliser, but could this be the crank shaft pick up?
will try again to get fault codes but any thoughts just now are welcome
It's a 02  Omega 2.6
many thanks
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
Re: Occasional Non Start
« Reply #1 on: 16 April 2008, 17:27:15 »
Sounds like the crankcase sensor's on the way out.
ians
  • Reading
« Reply #2 on: 16 April 2008, 17:45:41 »
Is that the same as a crankshaft sensor? :-?
bob.dent
  • Hertfordshire
« Reply #3 on: 16 April 2008, 17:49:50 »
Same thing - just my terminology!  ;)
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #4 on: 16 April 2008, 18:00:29 »
yep crank sensor - replace asap as it will get worse to the point it will let you down and simply not start !
ians
  • Reading
« Reply #5 on: 16 April 2008, 18:04:19 »
I know - just didn't want to be too rude ;)
Dazzler
  • Haverhill, Suffolk
« Reply #6 on: 16 April 2008, 20:37:45 »
You might want to change the fuel filter as well, as this gave me alot of starting issue problems on mine ;)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #7 on: 16 April 2008, 20:38:53 »
Do the Paperclip test mate and put the results on here so someone can tell you what they are :y
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
« Reply #8 on: 16 April 2008, 20:44:57 »
You can't on an 02 2.6.
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #9 on: 16 April 2008, 20:46:54 »
Why?
Get rid then and have a 2.5 or 3.0  ;D
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #10 on: 16 April 2008, 21:36:22 »
Get one of Pete's tech2 leads.  ;D ;D
TuBy's new whipping boy.
shanjon
« Reply #11 on: 16 April 2008, 23:48:33 »
my 3.0 very often does this but i have found that if i open bonnet and slam it , it will start straight up,  strange ways these cars have
keith2.2
  • Lincolnshire
« Reply #12 on: 17 April 2008, 00:20:01 »
the fact you say it very often does it suggests maybe your slamming technique doesn't solve the problem  ;)
2.2 litre, 210bhp, 910kg stripped honda civic
LPG'd MV6 Omega
VXmega
  • Dumfries
« Reply #13 on: 17 April 2008, 13:23:22 »
Many thanks so far .......... I still don't have any codes as yet but where do we find the part number on the crank sensor so i can pop into the dealers later.......... How much are we talking here for this part?
Regards
« Reply #14 on: 17 April 2008, 13:34:32 »
iirc i paid about 60 quid for one for my 2.5 a few months back.
