Author Topic: plenum  (Read 4204 times)
Richie London
  • heathrow
plenum
« on: 17 April 2008, 21:14:37 »
ive just been reading a few posts and hadnt noticed before that the 4 tubes at the back of the plenum have no jubilee clips to hold them on, they are very tight anyway but does this matter much or not. they have never moved but should i go and get some first thing tomorrow
richie
hotel21
  • The Kingdom of Fife
Re: plenum
« Reply #1 on: 17 April 2008, 21:17:39 »
The tubes on mine are a straight push fit.  Used to be cabletied but, after the last 'doo', I never replaced them.  No probs to date....
Iainv6
  • Kinross
Re: plenum
« Reply #2 on: 17 April 2008, 21:18:29 »
Mine have none either, so i hope it's normal :)
Dazzler
  • Haverhill, Suffolk
Re: plenum
« Reply #3 on: 17 April 2008, 21:20:14 »
Nope, no clips just a tightish dry push on as there are no fluids in there ;)
Richie London
  • heathrow
Re: plenum
« Reply #4 on: 17 April 2008, 21:46:16 »
i was getting worried there. can put the toilet lid back down now  ;D ;D
richie
Re: plenum
« Reply #5 on: 17 April 2008, 21:55:48 »
Originally the two larger breather pieps would of had some clips fitted......the smaller ones are just push fit.
amba
  • Medway towns
    • German V6
Re: plenum
« Reply #6 on: 17 April 2008, 22:44:58 »
I have original VX spring type clips on both the 2 outer tubes ,but the 2 inner tubes have no clips .I often wondered if that was correct but looks like mine is ok aswell.
Re: plenum
« Reply #7 on: 17 April 2008, 23:16:34 »
.. and just to add to the confusion I have clips on all four of mine. Doubt they'd go far without though, TBH.
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: plenum
« Reply #8 on: 17 April 2008, 23:21:50 »
And just to put some icing on that confusion...
I have 4 clips on one set in one car and none on the other car...
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
Re: plenum
« Reply #9 on: 18 April 2008, 08:04:30 »
i had metal clips on the larger two pipes on mine but replaced these with small jubilee clips last week
PM with your requests.
    • 530D M Sport, 330i Coupe
Re: plenum
« Reply #10 on: 18 April 2008, 08:43:00 »
Got them on three of mine!  :P
bighed
  • Shropshire
Re: plenum
« Reply #11 on: 18 April 2008, 08:47:39 »
Did have two on bigger pipes but got none now  ;D :P
HNO3GOH
  • Somerset
  • Play time.
Re: plenum
« Reply #12 on: 18 April 2008, 10:00:17 »
Mine also has clips on two two outer pips   :)
ians
  • Reading
Re: plenum
« Reply #13 on: 18 April 2008, 10:33:27 »
any other permutations...?
The original spring clips need the proper tool (or some invention) to reinstall hence why once removed they don't often go back.   They are also a prime candidate for dropping down the intake ports so take them off the pipes before lifting the plenum.
Re: plenum
« Reply #14 on: 18 April 2008, 10:39:23 »
I wouldn't use Jubilee clips as they can be over tightened, try cable ties ;)
