Author Topic: hi there everyone pls help  (Read 2913 times)
omegaleigh
  • london
« on: 18 April 2008, 18:03:28 »
my beloved omega 3.0 elite auto stopped working yeasterday but soon started again after 10mins i had a message on the display that read AUTOMATIC GEARBOX but after 10mins like i said it starts agian and drives lovely after about half an hour it bloody stops again any ideas please help.....
leigh :o
Danny
  • Wigan, Greater Manchester
Re: hi there everyone pls help
« Reply #1 on: 18 April 2008, 18:05:48 »
gearbox fault?
dene wakefield lad
  • wakefield yorkshire
  • my 1st love
« Reply #2 on: 18 April 2008, 18:10:57 »
 ::)sounds like box prob :'(
omegaleigh
  • london
« Reply #3 on: 18 April 2008, 18:11:13 »
hi there do you think i need gearbox oil if so is there a dip stick and where is it
dene wakefield lad
  • my 1st love
« Reply #4 on: 18 April 2008, 18:11:55 »
there isnt 1,i think? :-/
Marie
    • 2ltr LPG Estate
« Reply #5 on: 18 April 2008, 18:15:43 »
Exact symptoms i had when i had water in the gearbox.
once it had cooled the gearbox worked ok again.
you might be lucky and find that the oil level is incorrect and the box has too much oil in it.
i would check the following:
1. radiator connections to cool the gearbox oil, ensure they are not leakin.
2. gearbox breather is hi up underthe bonnet.
3. condition of the oil.
i would do a complete gearbox oil change. if you find waterin your gearbox oil. its bad news as the water distroys the gaskets within the gearbox.
Sorry for the bad news but if you do have water in the box you might have to look at replacing the gearbox. worst case.
Grumpy
  • Manchester
« Reply #6 on: 18 April 2008, 18:16:20 »
leigh :o
No dipstick I'm afraid.
Have a read of this by 'Marks DTM Calib'.
http://www.omegaowners.com/forum/YaBB.pl?num=1152783586
Marie
    • 2ltr LPG Estate
« Reply #7 on: 18 April 2008, 18:25:08 »
You will need a ratchet and a 13mm socket to undo the filler plug it might be a bit stiff if it has not been off before.
the copper washer will ether need replacing or heating. i have replaced mine they are about 50p from vx.
i tend to use a litre bottle to top up and top the lltr bottle up as required. makes life easyer to record how much oil you have put in it.
i have got topping up the box down to a "t" i dont even jack the car up anymore ( i can side my skinny arse under the car with out it) ;D ;D i just find a level spot somewhere and park the car on it.
bustedomega
  • Canterbury
« Reply #8 on: 18 April 2008, 18:26:00 »
i have had a similar problem recently :'(, and the garage said the box was shafted! After being told that a recon box would set be back £1500, I managed to pick up a 2nd hand box for less than £100 and now there is no problem 8-)
