Author Topic: Auto box question?  (Read 1996 times)
JonR
  • Gloucestershire
Auto box question?
« on: 17 April 2008, 13:21:45 »
when I Floor it From a standing Start it seems to take a little while For the box to  catch up. is this normal?
 Never owned an Auto Before so cant compare
Omega Steve
  • Margate, Kent, UK
Re: Auto box question?
« Reply #1 on: 17 April 2008, 13:29:23 »
That depends, are we talking about a flat spot here or a fraction of a second hesitation ? Auto boxes work very different to manual boxes but they are generally quick but they do have more to do than there manual counterparts. ?
« Reply #2 on: 17 April 2008, 13:32:35 »
first auto i had ,i thought there was something wrong with it,it felt a bit like driving a manual with a slipping clutch.just took a bit of getting used to.
JonR
  • Gloucestershire
« Reply #3 on: 17 April 2008, 13:43:42 »
more like the initial slippage, Just Feels odd
« Reply #4 on: 17 April 2008, 13:46:51 »
If the fluid level is low, it makes initial pick-up worse .. might be worth checking the boxes fluid level .. :)
Steve1077
« Reply #5 on: 17 April 2008, 13:50:23 »
Well the revs do go up on an auto when you press the loud pedal, its not like a manual where the revs are directly linked to speed, it took me a while to get the revs just right for maximum MPG, you can be doing 500RPM more and still be doing the same speed a lot of the time
« Reply #6 on: 17 April 2008, 13:59:04 »
If you floor it from a standing start an auto should rev to perhaps 2000 / 2200 RPM and the revs should then increase following the car's speed until almost the red line where it will change up.
It might feel a little more sluggish than a manual, firstly because 1st gear in an automatic gearbox is relatively high geared (equivalent to 2nd in a manual usually, however, the torque converter does add a slight variability to bring the ratio back down) and secondly because the engine has to pick up from idle speed, under load, until torque is transferred to the wheels. In a manual, the driver can "anticipate" the start and hold the engine RPM above idle without load, and can also transfer torque to the wheels much more shaprly using the clutch, which certainly feels faster.
I would have concerns if the engine revs at the instant you floor it rise to more than around 2K rpm, or fail to reach this valve, waver around as the car pulls away, or falter. In addition, when the box shifts up a gear the revs should drop smartly. If they linger before dropping, or the box feels like it's "slipping" I'd do a fluid and filter change ASAP (in fact, I'd do one anyway if you don't know when it was last done).
Autos do respond differently to manuals, and will feel odd to drive if you're not used to them. In a manual, engine RPM depends only on the gear you are in and the speed you are doing.
At low speeds, and automatic gearbox has a constantly changing gear ratio so engine revs will also depend on engine load (how much throttle you're using). This makes it feel like you're driving a manual with a slipping clutch at first.
JonR
  • Gloucestershire
« Reply #7 on: 17 April 2008, 14:04:36 »
thanks For the wealth of Info Kevin.
weeman
  • lanarkshire
« Reply #8 on: 19 April 2008, 21:17:31 »
does this happen when engine is cold? if so, the ecu holds holds back the gear changes when cold to allow the engine to reach optimum tempreture quicker for more efficient cat function. :y
