Author Topic: Check oil level  (Read 1420 times)
denisaok
  • East London
Check oil level
« on: 21 April 2008, 02:48:36 »
Hi all
I did an oil change on Friday and all seemed well but early this morning MOnday I was doing about 80 MPH and Check oil level came up on the MID should I be worried .If i should what should i do  :-/
To ask a question and feel idiotic for a moment is better than not to ask and be idiotic for a life time.
Re: Check oil level
« Reply #1 on: 21 April 2008, 04:50:55 »
Hi all
Have you dipped it? If the level is OK via the dip stick then you've got a faulty low level switch in the sump, or the connector has become loose/detached.
Mike Collins
  • North of Bristol
Re: Check oil level
« Reply #2 on: 21 April 2008, 08:43:51 »
I find it does not need to be very low for the warning to appear, around halfway between the lines can trigger mine.
ians
  • Reading
Re: Check oil level
« Reply #3 on: 21 April 2008, 11:59:11 »
Hi all
I would check the oil level if I was you... ::)
On mine that warning comes up at half way between the marks (= 1/2 litre down).  Could just be the oil filter filling up.   Top up to the level and see how you go.
