Pages: 1 [2] 3  All   Go Down
Author Topic: Knocking over speed bump  (Read 7047 times)
VX1
  • Reading, Berkshire
Re: Knocking over speed bump
« Reply #15 on: 21 April 2008, 20:55:28 »
If you are getting a knock from the front every time you go over a speed hump and braking then this is caused by the lower front wishbone bushes being worn. When you replace the wishbones also replace the drop links as well due to removing them to give you more movement for attaching the wishbones to the front hub. Best to change wishbones then that way the front end is new and won't need repalcing for another 12 months minimum. Make sure you get the FAI drop links, 1. cause they are cheaper than vx, and 2. last longer than vx.
Paul  :y
Vx Trade club card holder
Halfords trade card holder
omegalyn
« Reply #16 on: 21 April 2008, 20:56:49 »
Had the same nasty noise on my 2.0, if it’s the same setup, changed the wish bone bushes and the steering idler,  been quiet ever since.
Lyn
markey mark
  • SLady bitshorpe north lincs
« Reply #17 on: 21 April 2008, 20:57:56 »
i would go bottom arms bud !!  :y
VX1
« Reply #18 on: 21 April 2008, 20:59:12 »
Front wishbones are the same on all the omegas from 2.0ltr through to the 3.6 I believe.
« Reply #19 on: 21 April 2008, 21:05:45 »
Dang .. have I missed something .......   :)
 ;D ;D ;D ;D
VX1
« Reply #20 on: 21 April 2008, 21:07:41 »
 ;D ;D ;D ;D
OOOPPPPSSS ment to put 3.2. There are only a few 3.6 omegas but the police force seem to have them.  :(
DC
  • Switzerland
« Reply #21 on: 21 April 2008, 21:36:07 »
a question for resident experts (only for info - sorted mine out 2 weeks ago). what are actually drop links for? what would happen if you were to remove them and drive without them - long term?
« Reply #22 on: 21 April 2008, 21:47:19 »
They connect the ends of the anti-roll bar to the car's suspension. The anti--roll bar helps to transfer the cornering forces from one side of the car to help the wheel on the other side of the car to stay on the road surface.
« Last Edit: 21 April 2008, 21:48:04 by Andy_B »
hotel21
  • The Kingdom of Fife
« Reply #23 on: 21 April 2008, 21:52:38 »
They join the front anti roll bar which is located across the vehicle to the suspension on each side.
As one side of the suspension compresses under cornering the drop link transfers some of that movement through the anti roll bar (theres a clue there  ;) ) to the suspension on the other side of the vehicle to reduce (or attempt to equalise) the roll, thus improving handling as well as passenger comfort.
If its removed from one side but not the other wrong handling characteristics will result, as will complete removal from both sides.  Not recommended, other than for the shortest of short term diagnosis purposes......
DC
  • Switzerland
« Reply #24 on: 21 April 2008, 21:57:01 »
thank you! i have previously had a fwd car which did have anti-roll bars and i know what they are for, but cant remeber it having any drop links
Golfbuddy
  • Cornwall
  • I'm On An Economy Drive
« Reply #25 on: 21 April 2008, 23:15:47 »
Out of interest, what was the answer here? Drop links? Or wishbones? Or both?
[size=24]        [/size][/b]
hotel21
« Reply #26 on: 21 April 2008, 23:19:28 »
Initial answer was drop links.  Thats what I would go for, certainly the cheapest/quickest investigation/repair option rather than do the bottom wishbones....   ;)
Golfbuddy
  • Cornwall
« Reply #27 on: 21 April 2008, 23:20:52 »
Cheers Broocie.  :y
« Reply #28 on: 21 April 2008, 23:22:49 »
My fubar'd drop link was most noticable if you bounced the car by lifting the appropiate corner rather than bouncing it by pushing it down.
DJ Pete
  • Chelmsford, Essex.
« Reply #29 on: 21 April 2008, 23:50:17 »
So, in a worst case scenario, with bumping from the front end when negotiating speed humps and under hardish braking, what parts should be looking to check/replace?
Pages: 1 [2] 3  All   Go Up
