Author Topic: Problem with auto gearbox  (Read 2911 times)
mx6
« on: 24 April 2008, 13:16:58 »
Hi,
My brother in laws Omega has a problem with the gearbox and we arent sure how serious it would be to fix.
Its a T reg 2.5 V6 GLS auto and its not changing gears when in drive and doesnt seem to go over 2500rpm. He has to manually go through 1st, 2nd, 3rd and then drive and all the lights on the side of the gear lever are continually lit.
Has anyone come accross this and if so, does it means its f**cked or is it a basic fault.
Thanks for any help.
Re: Problem with auto gearbox
« Reply #1 on: 24 April 2008, 13:26:14 »
Sounds like the selector might be FUBAR - previous reports of misbehaving lights indicate this.
I believe the switch is "cleanable" with care, although it looks like most folks replace with one from a "breaker"
Have you driven through standing water recently ?? This seems to do the selector a lot of harm !!! :)
Does the EML light come on at all ?? If so it will probably need a tech2 to read the gearbox ... "cheapo" and "paperclip" don't read the gearbox AFAIK..
HTH
« Last Edit: 24 April 2008, 13:27:14 by entwood »
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
« Reply #2 on: 24 April 2008, 13:28:06 »
Almost certainly gearbox selector switch. I had exactly the same problem recently and replacement selector switch sorted it.
mx6
« Reply #3 on: 24 April 2008, 13:29:07 »
Thanks, yes i forgot to mention, the EML light does come on as well.
« Reply #4 on: 24 April 2008, 13:31:40 »
Do the "paperclip" test anyway to check out the EML codes .. takes but a few minutes ... let us know the result .. you MAY have more than one problem ......  :(
Paperclip instructions :
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
mx6
« Reply #5 on: 24 April 2008, 13:38:27 »
Thanks guys, will do the paperclip tets tonight just to see.
Any idea how much a selector switch costs, or is it something that can be obtained from a breakers?
Cheers
bob.dent
  • Hertfordshire
« Reply #6 on: 24 April 2008, 14:03:18 »
Cheers
I think to buy new they're in the region of £150 but you could try looking in the Car Parts Bits For Sale & Wanted section on this forum or try a breakers. There are quite a few good online breakers search engines such as www.partsgateway.co.uk or www.breakeryard.com that you could try.
mx6
« Reply #7 on: 24 April 2008, 14:58:12 »
Can anyone tell me where to look for the selector switch.
Top of the engine, bottom??
Thanks
markey mark
  • SLady bitshorpe north lincs
« Reply #8 on: 24 April 2008, 15:03:49 »
passenger side of gearbox bud ! :y
FastFred
  • Luton UK
« Reply #9 on: 24 April 2008, 16:04:28 »
I doubt if it's the selector switch
Have you tried oiling it? when mine did that i oiled the gearstick and it started working again
maybe it just needs oiling
« Last Edit: 24 April 2008, 16:06:01 by FastFred »
I am the Fastest.. oh yes i am
markey mark
« Reply #10 on: 24 April 2008, 16:23:33 »
selector switch is a more common problem with omegas causes all lights in car to light up or flash !! ::) ::)
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #11 on: 24 April 2008, 16:31:56 »
Have you driven through any flood water recently???
Marie
    • 2ltr LPG Estate
« Reply #12 on: 24 April 2008, 16:48:20 »
When the lights on the gearbox lever light up like a christmas tree it tends to be the selector switch.
you can remove it quit easily from the box and dry it out clean it and re oil it.
i will go and get a picture of one now for you brb :)
Edit:
Here you go..............
« Last Edit: 24 April 2008, 16:55:22 by marie »
mx6
« Reply #13 on: 24 April 2008, 16:56:49 »
you guys have been really helpful. I have used forums for various things in the past and you guys have been the best.
and thanks in advance for the picture :)
Marie
    • 2ltr LPG Estate
« Reply #14 on: 24 April 2008, 16:57:25 »
Picture is added above^^^ :)
Give me a shout if you get any snags.
i am rather intermet with these gearboxes at present! ;) ;D ;D ;D
« Last Edit: 24 April 2008, 16:59:16 by marie »
