Author Topic: which spark plugs  (Read 3942 times)
cockneyboy100
  • watford
  • this aint me, its my cat
which spark plugs
« on: 16 April 2008, 10:11:30 »
doing a service this weekend,  so many spark plugs, to choose from, what do you reccomend,  have heard ngk iridiums are good.
phill
  :y :y :y :y :y
a little tip for you all, never buy stockings for a mermaid
Re: which spark plugs
« Reply #1 on: 16 April 2008, 10:15:42 »
Vx twin electrode ones.....4 electrode parts offer no advantage and can actual shield the flame front....
cockneyboy100
  • watford
« Reply #2 on: 16 April 2008, 10:17:21 »
have you used these plugs before.
« Reply #3 on: 16 April 2008, 10:25:54 »
Which?
Vx - Yes, many times
Tried and fitted many more expensive types and had no improvement (not that you would expect any) and in some cases poorer running (i.e. Bosch Super 4's)
What you have to consider is that
1) The Omega engine are pretty efficent so dont have massive cylinder temps unlike say a Turbo car
2) The engine management setup really extends the plug life through tight control of timing and mixture
If you check a set of 40K plugs and measure the elctrode gap, it will be pretty much the same as the day it was fitted!
« Reply #4 on: 16 April 2008, 10:28:28 »
 ..... and how do you check the gap on multi electrode plugs?  :-?   ;)  ;)
cockneyboy100
  • watford
« Reply #5 on: 16 April 2008, 10:29:23 »
thats great, cheers for your help, vx it is then
phill
 :y :y :y :y :y :y
mkaminski100
  • Basingstoke
« Reply #6 on: 16 April 2008, 11:16:12 »
Take GM plugs, or NGK. It is possible that BOSH is making GM spark plugs, but original BOSH just dont work as well as GM's or NGK.
Richard A
  • Aldridge, West Midlands
« Reply #7 on: 16 April 2008, 17:47:01 »
Had problems with GM plugs (misfire under load), fitted NKG Irdium plugs at 117k, speedo now at 142k ie covered 25k, checked 2 weeks ago and they still look like new, worth the money  :y
regards
richard a
richard a
mahony
  • london
    • omega elite 3.0
« Reply #8 on: 16 April 2008, 18:20:24 »
i have used bosch super 4's with no problems (4 electrode) idle is actually smoother than the standard 2 electrodes i took out. :y
« Reply #9 on: 16 April 2008, 19:27:58 »
You use gauge rods....
« Reply #10 on: 16 April 2008, 19:30:01 »
Hows that a comparison....ow look, these new plugs work better than these old ones....  :-?
The 4 electrode ones are not better, they only extende the service interval by which time they have often worked loose any way......on a normaly aspirated car, fancy plugs only empty your wallet.....you want good quality standard plugs, not fancy snake oil based things
MV6Man
  • Finland
« Reply #11 on: 16 April 2008, 21:26:30 »
regards
richard a
What´s the part no for those iridiums?
They are coming on 3.0 but i assume that they will work in it too
Richard A
« Reply #12 on: 17 April 2008, 20:27:23 »
NGK Iridium IX Part no BKR6IX, 6418.
regards
richard a
richard a
trebor
  • Swindon
« Reply #13 on: 24 April 2008, 23:24:15 »
I put in the LPG versions and what a difference!  Engine smoother, more powerful and economy now at 21 (up from 18) and I changed plugs halfway through a tankful of LPG - so hoping for even better on this new tankful.
BKR6EIX-LPG
mkaminski100
  • Basingstoke
« Reply #14 on: 25 April 2008, 17:00:13 »
How much are these? Are they really worth it?
