Author Topic: false readings on mid  (Read 3054 times)
cockneyboy100
  • watford
  • this aint me, its my cat
« on: 25 April 2008, 20:06:00 »
have been  getting false readings on my mid,  tailight out headlight out, low windscreen fluid.
but all is ok,  any ideas please
 :y :y :y
a little tip for you all, never buy stockings for a mermaid
markey mark
  • SLady bitshorpe north lincs
Re: false readings on mid
« Reply #1 on: 25 April 2008, 20:08:50 »
cheap bulbs will give false readings bud !! and could be level sensor in wash tank !! :y
Tab
  • Telford
« Reply #2 on: 25 April 2008, 20:12:16 »
Might be a common problem, i get coolant level and brake pad but both are ok.
markey mark
« Reply #3 on: 25 April 2008, 20:14:18 »
its not the mid its the sensors brake pads may be ok but the wear wire could be broken and the level sensor could be stuck down on shaft !! :y
cockneyboy100
  • watford
« Reply #4 on: 27 April 2008, 12:45:39 »
have checked all bulbs, no cheap ones fitted, still got errors on mid, any ideas please
 :y :y :y :y
markey mark
« Reply #5 on: 27 April 2008, 14:45:41 »
must be the bulb check ecu then fella !! think i have a spare in garage £7.50 inc postage :y
« Reply #6 on: 27 April 2008, 19:54:14 »
remember there are 4 tail lights. Check them all.
Taxi_Driver
« Reply #7 on: 27 April 2008, 21:14:46 »
And im fairly certain number plate bulbs are checked as well.....so check these are working as well  :y
« Reply #8 on: 27 April 2008, 21:18:24 »
Looking at diags for 2002/2003 models, numberplate lights are not checked.
cockneyboy100
  • watford
« Reply #9 on: 27 April 2008, 21:27:07 »
didnt realise there were 4 tail lights,
Taxi_Driver
« Reply #10 on: 27 April 2008, 21:36:01 »
Ah ok.....thought they were.......i stand corrected  :y
Good job i wandered round the back of my omega last night when the lights where on.......number plate lights both working  :y
Taxi_Driver
« Reply #11 on: 27 April 2008, 21:39:51 »
Saloons have 4, estates have 2  :y
« Reply #12 on: 27 April 2008, 22:01:21 »
A tail lamp & a stop/tail lamp on each side.
cockneyboy100
  • watford
« Reply #13 on: 28 April 2008, 13:13:12 »
were do i find the bulb check ecu please.
 :y :y :y :y :y :y
Sasha75
  • Finland
« Reply #14 on: 28 April 2008, 14:50:32 »
Could be just a bad connect with the bulb, I have the same fail now and then. I´ve seen it flash once when my wife were driving the car.
