Author Topic: Checking my purchase!  (Read 3757 times)
GinoGinelli
  • London
« on: 01 May 2008, 14:22:14 »
Hi people,
Just bought a '96 2.5 CD on ebay (don't say!), sounds a genuine car but I obviously have to give the car a once over to check all is well. Are there any nasty, out of the ordinary faults I should look for?
Apparently it has a pile of history, service a few K ago and cambelt 13k ago.
Many thanks!
P.s I did try searching but I'm new to using message-boards, sorry if questions like this have got a bit boring!
« Last Edit: 01 May 2008, 14:23:32 by GinoGinelli »
amba
  • Medway towns
    • German V6
Re: Checking my purchase!
« Reply #1 on: 01 May 2008, 14:31:47 »
Even if the car has a receipt( ?? ) for the cam belt and tensioners being replaced would still be worth factoring that cost in aswell,your peace of mind and  own knowledge is better than a piece of paper.
shyboy
  • Southport, merseyside.
    • Mazda 6
« Reply #2 on: 01 May 2008, 14:41:22 »
If you cannot get positive proof that the cambelt/tensioner work has been done it's a very wise insurance to do it anyway. But if you are sure it's OK, you'll save yourself the cost and time, (and spend your driving days wondering).   :-/  :-/ It's a much cheaper option to do it.
Also check and clean the breather system per the guides on here. This, and max. 5000 mile oil changes, are the most certain way of ensuring minimum problems in the months/years ahead. Enjoy a great motor car.
I spend time browsing the maintenance guides. In no time you'll be an Omega 'expert'.
« Reply #3 on: 01 May 2008, 14:41:51 »
Keep an eye out for oil leaks from the cam covers. May be worth checking the plug wells are free of oil before the plug leads get deep fried. Cleaning out the breathers and giving it a service is probably a good preventative step here.
Keep an eye on the coolant level as there are a couple of common problems that will cause it to leak. If it doesn't appear to have been changed recently, is blue/green colour or the mixture looks weak flush it through and replace with GM long life (Red) coolant.
Front suspension can be prone to play and mis-alignment so it's worth giving this a once-over and also checking that the tyres are wearing evenly (be particularly careful of excessive shoulder wear on the front tyres).
Check the drains in the scuttle panel either side are clear so nothing gets drenched by collected rainwater.
That's about all I can think of at the moment. No doubt others will have more advice.
« Reply #4 on: 01 May 2008, 14:43:19 »
check cam covers for oil leaks,if the breather are or have been blocked the cam cover gaskets act as the pressure relief valve . :y
HolyCount
« Reply #5 on: 01 May 2008, 15:24:13 »
........ and ...... welcome to the fold  :y Post some pics in the gallery and generally browse around
GinoGinelli
  • London
« Reply #6 on: 01 May 2008, 16:53:53 »
Wow, loads of info. Cheers!
The bills (£0000's worth apparently- a good or bad sign I don't know!?  ::) ) and SH are all main dealer from what he said- inc. the cambelt if I remember right. Its a £500 car at the end of the day so I won't be too fussy though!
I'll go over the car & change all the all the oils/filters etc when its back
Cheers again!
« Last Edit: 01 May 2008, 17:04:23 by GinoGinelli »
GinoGinelli
  • London
« Reply #7 on: 02 May 2008, 17:40:32 »
Got the Omega!
Drove 100+ miles back without missing a beat... love the car! Its like one of those american state cruiser-mobiles, almost felt like we were off to the nick! The interior is a bit old skool, especially after the '05 plate Mondeo we went up in, but I like that. Soo comfy.
Just a bit of rust on the drivers side door bottoms and the digital screen thingy to sort but for 500 quid I can't complain. Oh, and it had a full tank of petrol and new tyres as well!
Touch wood, well happy!
HolyCount
« Reply #8 on: 02 May 2008, 17:43:53 »
Got the Omega!
practically covers the cost then, with the price of petrol !!!!  ;D
GinoGinelli
  • London
« Reply #9 on: 04 May 2008, 09:58:22 »
Hi, the cambelt was changed at a main dealer in April 2004 @ 80,000 miles (93k now)... would changing it now be OTT?
Never seen a car with this much history, absolutely reams of the stuff and all at the same dealer. Had the rocker cover gaskets, wishbones etc done last year as well. Still can't believe I got this car for 500 quid!
« Last Edit: 04 May 2008, 10:05:20 by GinoGinelli »
« Reply #10 on: 04 May 2008, 10:14:00 »
cambelt is due to be changed.every 40,000 or 4 years,whichever comes first. :y
amba
  • Medway towns
    • German V6
« Reply #11 on: 04 May 2008, 10:38:25 »
As I said earlier,at 4 years old that cambelt and tensioner set really should be top of your list to do...whilst sounds like a very good buy would be tragic if a tensioner failed and caused extensive damage.Also well worth a oil/filter cahnge as the car only seems to have covered 13k in 4 years and things do need to move regularly to work properly.Not being a scaremonger..just words of advise...enjoy your new car
« Reply #12 on: 04 May 2008, 10:40:57 »
NO!
Cambelt and tensioners must be changed every 40k or 4 years.
Change it now.
GinoGinelli
  • London
« Reply #13 on: 04 May 2008, 10:51:49 »
Well, I had a close look at the belt and there are tiny cracks all over it! Took her for a long drive yesterday as well.
Not going to drive it until its done now. Will give it a full service as well. I'm guessing it would be wise to get the gearbox oil changed as well as its an auto?
Seriously- thanks for taking the time to advise me, much appreciated!
« Last Edit: 04 May 2008, 12:03:25 by GinoGinelli »
« Reply #14 on: 04 May 2008, 11:08:32 »
Well, I had a close look at the belt and there are tiny cracks all over it!  ....
Which belt have you had a look at? Cam belt or 'fan' belt?
