Author Topic: Wheel movement  (Read 1682 times)
Sipey
  • Maidenhead
Wheel movement
« on: 07 May 2008, 11:16:14 »
Hi All,
Had to change a tyre yesterday and noticed significant movement in the front nearside wheel. This was horizontal movement as opposed to vertical movement. Searching through the forum suggested various could be's, most likely being a steering idler. Before I go and get the part, thought I would check with you first  :)
Many thanks,
Mark
kcl
  • Finland
    • Volvo V60 D4 -14
Re: Wheel movement
« Reply #1 on: 07 May 2008, 11:31:31 »
The wheel is moving back and forth? Sounds like wishbone bushes to me...
Just out of interest, how can you tell a worn idler? Imho it'd feel like a play in steering?
Matchless
  • Nottingham
    • A white van
Re: Wheel movement
« Reply #2 on: 07 May 2008, 11:36:12 »
Find the cause of the movement before spending on parts.
Get someone to rock the steering wheel whilst you reach underneath at all the ball joints and the idler pivot....any play should be obvious. Note you should do this with the engine running to eliminate slack in the power steering box so make sure it cant move!!
Other possible source of play is a completely shot front wishbone bush...should be obvious if you apply a little leverage.
Re: Wheel movement
« Reply #3 on: 07 May 2008, 11:50:48 »
You could always put your 'numpty hat' on & ask at somewhere like ATS or Kwick-Fit to stick it on the ramps & have a look for you. If you go when they're quiet ....
Page created in 0.009 seconds with 21 queries.
