Author Topic: Can cam sensor fault be intermittent?  (Read 1059 times)
the hamster
  • Nottinghamshire
« on: 09 May 2008, 08:12:43 »
Hi all, replaced my crank sensor recently as I was having starting problems and all was good again.
Now we have a new problem. Paperclipped her and she shows an 0340 (we have a 1998 manual 2.0 16v)
Thing is, it only does it every now and then. EML has only come on once and doesnt come on with the fault.
When driving it will start to run rough and sound like an induction kit has been fitted but performace is non existant. Then it will cure itself and carry on ok for a bit.
Question is, are they tempermental or should it just fail? I've seen loads of threads where people have tried more than 1 sensor to cure the problem so I want to get it right.
Any thoughts and links to suppliers would be handy.
Cheers, Sturt and Kirsty
Dazzler
  • Haverhill, Suffolk
Re: Can cam sensor fault be intermittent?
« Reply #1 on: 09 May 2008, 08:55:01 »
Mine was intermitant on my 2.0 ;) (camshaft sensor that is)
