Author Topic: tick tick tick tick tick....  (Read 3913 times)
bappy
  • HAVANT, Hants
  • Don't fart on the leather upholstery!
Re: tick tick tick tick tick....
« Reply #15 on: 12 May 2008, 12:57:42 »
OK... the faster the engine spins, the faster the ticking might this still be the tappets? If so am I likely to have done them damage or will new gaskets be likely to fix it?
A couple of times when starting up again after a long drive (ie when the engine is hot) it has been really lumpy for about a minute then settled down, I don't know if thats connected at all to the ticking or if it's my leads starting to break down with the oil leak.
Any garages around portsmouth/southampton that know what they are doing with these engines??? (X30XE) I think I'm in a little over my head now.  :-[
If at first you dont succeed, Rev it harder!
« Reply #16 on: 12 May 2008, 13:26:07 »
I personally would do breathers and gaskets at the same time.
That way you won't strip it down twice!
ians
  • Reading
« Reply #17 on: 12 May 2008, 18:33:30 »
I would do breathers first given your time constraints - and its not a seven hour job -what gave you that impression?
Ideally you do all at once as James says but I'm not sure that is realistic when doing it for the first time in 3 hours.    If your breathers haven't been cleaned then they do need doing no question about it.
Taxi_Driver
« Reply #18 on: 12 May 2008, 19:10:24 »
generally, manifold ticking quietens down when it warms up.  Followers possibly sound likely :(
I concur, manifold ticking on my 2.2 goes after about 30secs of engine running from cold.
« Reply #19 on: 12 May 2008, 19:10:31 »
If speed of ticking increases with engine revs likely to be tappet/follower.  Normally will quieten down when warm.
When i first had my V6 had noisy tappet when cold - 2 oil/filter changes later - quiet. ;)
bappy
  • HAVANT, Hants
« Reply #20 on: 13 May 2008, 14:27:31 »
intersetingly, the tapping suddenly stopped yesterday and hasn't started again. I guess a delayed reaction to an oil change? anyway I'm happy about that. What Im not so happy about is that my local vx dealership quoted me £184 for a set of gaskets for ONLY ONE BANK OF THE ENGINE!!!!
anywhere I can get these gaskets online for a respectable price??? cheers!
