Author Topic: which engine  (Read 2190 times)
ash18
  • midlands
which engine
« on: 12 May 2008, 14:19:50 »
ok so its coming up to me making a decision as to what omega to buy i want a manual and pleanty of power and no spec below a cd model and definatly want a saloon rather than the estate, i do about 300 miles a week but alot are short trips 15- 20 min so which engine am i going to be better off with the 2.0 petrol 2.5 v6 petrol 3.0 petrol or a diesel? oh and only got just over a grand to spend.  :-/ :) :y
only god can judge me
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
Re: which engine
« Reply #1 on: 12 May 2008, 14:24:36 »
I just purchased a 2.5 A good blend of power with resonable mpg. Problem is start stop driving kills the mpg on any car
ash18
  • midlands
Re: which engine
« Reply #2 on: 12 May 2008, 14:28:36 »
yer mpg is a pain but using an old corsa as a run around at the mo and its just about doing 25 to the gallon so anything better than that is good but my work pays for some of the miles which helps.  :y
Re: which engine
« Reply #3 on: 12 May 2008, 14:52:20 »
I would go for the 2.5, more power than the 2.0 and more MPG than the 3.0 :)
ash18
  • midlands
Re: which engine
« Reply #4 on: 12 May 2008, 14:55:08 »
good way of looking at it thanks   :y
shanjon
Re: which engine
« Reply #5 on: 12 May 2008, 16:12:11 »
from personal experience i have found the 2.0 can be underpowered as it is a heavy car for it to push ,
mantahatch
Re: which engine
« Reply #6 on: 12 May 2008, 16:14:06 »
Virtually all my journes are short ones, 6 miles to work and 6 miles home again, about 15-20 minutes. I had a 2.0 then my father gave me his 2.5. The difference in petrol is nil, and both have auto boxes.
The trip meter thingy says I do about 19.4 mpg with an average speed of 19 mph.
Mike
ash18
  • midlands
Re: which engine
« Reply #7 on: 12 May 2008, 16:23:06 »
yer was thinking the 2.0 was underpowerd had an old 8v many years back and couldnt pull the skin from a rice pudding 19mpg that scary but guess that expected of a v6 my work is 15 miles from my house its a good run but it the little trips i have to make to peoples houses (am a care worker/social worker) that the prolem but worth it for a nive v6 miggy :) 8-)
markey mark
  • SLady bitshorpe north lincs
Re: which engine
« Reply #8 on: 12 May 2008, 17:04:43 »
get a late 98/99 3.0 mv6 fella got all the toys and quite rapid !! :y
bappy
  • HAVANT, Hants
  • Don't fart on the leather upholstery!
Re: which engine
« Reply #9 on: 12 May 2008, 17:28:21 »
yer 3.0 mv6.... on a good run of 15-20 miles I get 28-30 mpg provided there arent too many roundabouts. I get 20-23 mpg round town. I think with the kind of driving you will be doing you will only notice 2-3 mpg difference for getting the 2.5
at any rate be very careful with the car you buy. check for oil leaks around the rocker covers. you can tell by oil dripping onto the exhaust manifold. If the engine has been jet/steam cleaned be very wary. pull out the middle plug leads from each bank to check for oil. get the seller to replace gaskets before sale if there is any sign of oil int he plug wells. this is the same for any omega v6.
also take a torch and shine it onto the belly pan. if it's got water on it it has likely got a cracked heater bypass valve which will use up some water and may eventually result in a nackered dispack.
I didn't check these things.... :(
the other major thing to check is for mayonaise under the oil filler cap as that would denote a possible failed oil cooler (a tad pricey to fix!)
These are I believe the most common engine problems to be wary of on the v6 marks.
If at first you dont succeed, Rev it harder!
Re: which engine
« Reply #10 on: 12 May 2008, 21:14:47 »
I do 18 miles each way to work... Mostly dual carriageway with about 12 roundabouts. As long as i behave with the loud pedal i get about 24mpg over the course of 4 days. I'd highly recommend an elite if you can get one!
Re: which engine
« Reply #11 on: 13 May 2008, 08:55:15 »
I'd go with a 2.5 Elite and then after a while if the wallet can stand the strain of the fuel bills, add a set of 3.0 cams ;)
« Last Edit: 13 May 2008, 08:55:56 by Elite_Pete »
ash18
  • midlands
Re: which engine
« Reply #12 on: 13 May 2008, 15:39:25 »
3.0 cams in a 2.5? what gain would i get from that? wolud love an elite do they do a 3.0 manual? :)
Re: which engine
« Reply #13 on: 13 May 2008, 15:43:07 »
The 3.0 cams bring the 2.5 pretty close to 3.0 BHP. A manual Elite is quite rare but worth it if you can find one ;)
« Last Edit: 13 May 2008, 15:43:41 by Elite_Pete »
