Author Topic: Complete noobie missing. . . . . . something?  (Read 5216 times)
Cheshley
  • Doncaster
« on: 26 April 2008, 15:31:41 »
Hello,
My mechanic pointed out to me yesterday that there appears to be a pipe missing from my engine!!!!!
On the underside of the round unit that attaches to the front of the intake manifold (technical terms, I don't know what that round unit is or what it does) there is an outlet that looks like it should have something connected to it.  Directly under this outlet there is a water hose which is now covered in what appears to be oil but I've never noticed this before.
Any suggestions?  Would a photo help? What effect would this missing connection have on my car?
Thanks
« Last Edit: 26 April 2008, 15:32:42 by Cheshley »
Albatross
  • Bedford
  • An LSD & an S2000!
Re: Complete noobie missing. . . . . . something?
« Reply #1 on: 26 April 2008, 15:33:38 »
Hello,
Thanks
Most probably, yes. That is if it isn't too much trouble.
Cheshley
  • Doncaster
« Reply #2 on: 26 April 2008, 16:08:00 »
apparently I can't just download a pic, I have to host it on another site and post the link or something like that, or I may have got that completely wrong......  If a pic is needed, PM me your email and I'll send it.
Grumpy
  • Manchester
« Reply #3 on: 26 April 2008, 16:14:31 »
http://photobucket.com/
Join the site (free) on the link above.
Upload your pics to the site.
Use the image link on that site to post your pics here.
Best you learn how to do it now, for future use, rather than relying
on other folk to post them for you from e-mails.  :y
Cheshley
  • Doncaster
« Reply #4 on: 26 April 2008, 16:21:30 »
Hope this works. . . . .
Cheshley
  • Doncaster
« Reply #5 on: 26 April 2008, 16:23:18 »
well, it almost worked, click the link and hopefully you can see what I mean.  There's a black pipe with a blue stripe attached to one connection but the other connection has nothing on it and that's where the oil(?) is coming from.
Grumpy
  • Manchester
« Reply #6 on: 26 April 2008, 16:36:43 »
Nearly there.  :)
If you click the Image Code on photobucket, underneath the picture,
a little yellow box pops up that says 'Copied'.
You then simply right click in the posting box on here, and click 'Paste'.
« Last Edit: 26 April 2008, 16:39:18 by Grumpy »
Cheshley
  • Doncaster
« Reply #7 on: 26 April 2008, 16:45:02 »
ahhhhhhhhhhh, now I see where I went wrong  :-[.
Thanks for that, you do realise that ALL posts will now be acompanied with full sized photo's in glorious technicolour. . . . .  ;D
platty
  • Cambridge
    • BMW 530d Sport
« Reply #8 on: 28 April 2008, 13:40:33 »
You seem to be missing a vaccum for your EGR valve. I can have a look and see where mine goes if you like...
If I was you, (as per the other thread) I would take the whole lot off, including the EGR and give it a good old clean up. Mine was filthy inside and the EGR wasn't even moving. It doesn't take long and is well worth doing.
Clean up the Jubilees and get them nice and tight when re-fitting it all as some hoses clamp onto plastic pipes which is a bit crap.
Cheshley
  • Doncaster
« Reply #9 on: 28 April 2008, 14:20:41 »
Would be great if you would have a look and let me know what it should look like, thanks.  I've got plans to get the inlet manifold off and get the plugs changed (per other thread) and while the manifold is off I'm going to put a new temp sensor in because the temp dial on the dashboard hardly moves, so while it's in bits I may as well have a go at cleaning the insides up.  Any recommendations as to what to use?
« Reply #10 on: 28 April 2008, 14:32:22 »
Thats more likely to be your thermostat.....that fact it does move (all be it only slight) sudgests it is working
« Last Edit: 28 April 2008, 14:34:18 by Mark »
platty
  • Cambridge
    • BMW 530d Sport
« Reply #11 on: 28 April 2008, 15:02:13 »
My TD never gets above 90 degrees normally. I ran without the viscous fan for a fortnight and it used to sit around 95 degrees all the time. So, I have decided to run it with the fan in the summer and leave it off in the winter.
With regards to cleaning your pipes out (on the omega ;D) I used Gunk degreaser in a 1litre can - not the spray type, but the brush on - allows you to get into all the nooks and crannies with a half inch brush.
Soak it, clean it all, wipe dry and refit. Ill get that pic tonight if possible. :y
Cheshley
  • Doncaster
« Reply #12 on: 28 April 2008, 15:04:26 »
Nicely, cheers bud.
Omegatoy
  • UK
« Reply #13 on: 28 April 2008, 20:02:46 »
EGR vac pipe falling off is common!!! if your mechanic was any good he would have seen it hanging down, it wont affect the engine running at all, but what it does do is allow gunk and crap to fall in your alternator eventually gumming it all up!!
Omegatoy
« Reply #14 on: 28 April 2008, 20:15:09 »
The black blue pipe is egr vac.  I think the other is some kind of drain.  Mine fell off, never did anything.  I'm now using a different (older) egr without the extra pipe.
Stat is easy to change on TD. My tip, when you remove the viscous fan, leave it off.
