Author Topic: poly v needs a cracker  (Read 4220 times)
weeman
  • lanarkshire
« on: 20 March 2008, 13:24:03 »
i have a 2000 2.2 petrol y22xe omega and have been told that my poly v belt tensioner or ildler is ready to go PPPHUT!!!!!
can someone please tell me whats involved to replace it :-?
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: poly v needs a cracker
« Reply #1 on: 20 March 2008, 15:40:16 »
guesing either aux belt tensioner or timing belt tensioner - who has advised you of this, whats the symptoms and whats your mileage ?
weeman
  • lanarkshire
« Reply #2 on: 21 March 2008, 17:20:27 »
thanks for the reply. its the auxiliary drive belt tensioner or idler running the alternator etc,
it was a vauxhall dealer who wanted to charge me over £150 to change it :-X
Mike Collins
  • North of Bristol
« Reply #3 on: 21 March 2008, 17:38:07 »
Utterly ridiculous, you can buy the tensioner pulley with it's bearing for no more than £30 or so.
If it's similar to the V6, one screw holds the pulley, 15 minutes?
It sounds like they want to change the whole tensioner assembly, you certainly don't need to that on a V6, anyone tried it on a four cylinder?
Mike Collins
  • North of Bristol
« Reply #4 on: 21 March 2008, 18:38:27 »
Just checked part numbers, 2.2 seems to be 9157948, it's listed as no longer supplied which is not helpful.
2.5 is 9157962.
I don't know what difference there might be, pulley diameter perhaps?
Unless the pulley is damaged is it possible to remove the bearing and replace with standard part?
weeman
  • lanarkshire
« Reply #5 on: 21 March 2008, 21:49:41 »
thanks for the replys, ill have a go at it on monday  :y
« Reply #6 on: 21 March 2008, 23:33:27 »
Albus Dumbledore
  • Bergen, Norway
« Reply #7 on: 22 March 2008, 01:27:32 »
You can't get an easier job. I just did it on mine, took about 3 minutes, so no worries :y
I can't believe they wanted to charge £150 for that!
weeman
  • lanarkshire
« Reply #8 on: 22 March 2008, 20:05:21 »
pheww!! feelin a lot better now  :D  thanks for the replys and links, ill let yoos know how i get on ::)
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #9 on: 22 March 2008, 20:57:59 »
A typical example of VX wanting to bend you over the work bench pulling your trousers down and shouting "pass the lube" :o
weeman
  • lanarkshire
« Reply #10 on: 23 March 2008, 20:20:23 »
heehee!!  if it wasnt for yoos guys they would probably have charged me another £50 for the lube as well :)
Tony H
  • liverpool
« Reply #11 on: 24 March 2008, 20:26:40 »
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #12 on: 24 March 2008, 21:18:18 »
Would Sir like some KY or has Sir brought his own. ;D ;D
TuBy's new whipping boy.
weeman
  • lanarkshire
« Reply #13 on: 27 March 2008, 18:59:33 »
re; auxiliary belt tensoiner,
located localy £37 inc vat,
fitted by myself in ten minuts,
money saved £120,
advice from Yoos guys PRICELESS!    :y
thanks for your help  ::)
Albus Dumbledore
  • Bergen, Norway
« Reply #14 on: 27 March 2008, 20:53:49 »
congrats! job well done :y Usually better to try yourself first 8-)
