Author Topic: Airbag warning light on  (Read 1519 times)
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
« on: 13 May 2008, 19:50:01 »
Ok If I've caused this myself then feel free to slap me with a wet kipper
I had a problem with the stereo in my car the front os door speaker didn't work. So I removed the trim today and started working back towards the stereo following the wires until I found the fault. So I undid the wiring loom at the door pillar and checked the speaker wires from the door to the speakers found them ok. Then I was asked to move the car so with the door wiring disconnect I started it up and moved it. I followed on with fixing the speaker problem I found the problem lied with the multiplug on the back of the stereo. For some reason theres the plug to the stereo and a little further up another plug. The fault was here so I disconnected it and using the ISO socket on my aftermarket stereo plug it straight into this plug. BINGO!! stereo works fine. SO I put car back together started it up and now I have the airbag warning light on  >:( >:( Now I guess I've dislodged something or by unplugging the door and turning the ignition on had one of the sensors unplugged. I did notice a blue control unit in the door but thought it might be something to do with the remote CL . I know I have to get this reset at a garage well I've just ordered some new software and now hope  when it turns up I can reset it myself. Is there any sensors in the dash by the stereo for tha airbag? am I right in now thinking the blue sensor in the door is for the seat airbags
I await my pounding with kippers please no frozen ones  :-[ :-[ :-[
markey mark
  • SLady bitshorpe north lincs
Re: Airbag warning light on
« Reply #1 on: 13 May 2008, 19:52:14 »
slap for you fella !! need to get it on tech 2 to get get airbag light reset !! that blue box in door is for side airbags !!  :y
« Reply #2 on: 13 May 2008, 19:52:53 »
Yes! :( You're a bit far from me for the wet kipper though! ;D
« Reply #3 on: 13 May 2008, 19:54:09 »
...need to get it on tech 2 to get get airbag light reset !! .....
A "Cheapo Tech II" will reset an air bag light.
doz
  • Southampton
« Reply #4 on: 13 May 2008, 20:07:51 »
I have a caradan software with elm327 interface. The problem being it only looks at engine codes. Just ordered the full package from them will be here in a day or two Specific for Vauxhalls. I'll have to wait and see if it's as good as my VAGCOM for VAG cars
« Reply #5 on: 13 May 2008, 22:08:26 »
Cheapo tech2 should reset - see if they is a member near you with cheapo...
« Reply #6 on: 14 May 2008, 16:03:33 »
I have a cheapo and am not too far away if I can help. I make regular journeys to the south coast to feed my gearbox change fetish :-X
doz
  • Southampton
« Reply #7 on: 14 May 2008, 18:43:00 »
My brothers outlaws live by you. I may take you up on that offer after friday. THe garage who are going to track it are going to try and reset it on Friday. I took it to a garage today but it wouldn't connect. He tried his gear on another car and had the same problem so it looks like his gear was up the shoot.
