Author Topic: Brake Pad Warning on MID  (Read 2060 times)
JueV6
  • Kent
« on: 15 May 2008, 22:07:29 »
Tis doing my head in now. Brake pad warning is on on my 98 Elite. New pads fitted, NEW SENSORS......(OMG £10 each ffrom Main Dealer)
Still On...help please >:(
Holds head in hands in dispare.
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Brake Pad Warning on MID
« Reply #1 on: 15 May 2008, 22:27:41 »
Check that they're plugged in correctly.
I like red cars
markey mark
  • SLady bitshorpe north lincs
« Reply #2 on: 15 May 2008, 22:58:08 »
and wires to car loom end of plug !!
ians
  • Reading
« Reply #3 on: 16 May 2008, 12:45:39 »
if it still shows after checking as above, try unplugging from the loom and shorting out the pins on the connector (car side) with paperclip or the like.
Do this on each side separately (when shorted the error message should go away) - that will tell you which side is playing up - it may be you have a faulty sensor.
ghondie
  • sheerness,kent,uk
  • Looking for work, any offers?
« Reply #4 on: 16 May 2008, 14:56:21 »
on another note, i dont have any sensors fitted to my car, the wiring is there but nothing connected to the pads.
is it possible that somebody judt chopped them off or might they have never been fitted?
could i just buy teh sensor and it will work straight away? or will it need setting up?
Cheers
nathan
Man with a mission. not sure what it is but i've got one
Sheerness Lifeboat Crew and ILB Mechanic
FRE07962128
« Reply #5 on: 16 May 2008, 15:03:48 »
Cheers
nathan
In my experience I am aware that the sensors can be worn away with the pads with excessive wear as I once had on a 3.0 Elite.  The garage who did the work (highly respected locally) had to order and fit the sensors with the pads and then connect them up. It is possible that your sensors have gone the same way as mine did and you need to replace these.  You will then be able to reconnect them to the system.  :y
ians
  • Reading
« Reply #6 on: 16 May 2008, 15:17:36 »
Well it may never have had them (no sure about cd - my cdx has them , but gls did not).  One thing for sure is if you just remove them (or don't replace when they have worn) the MID warning will be showing.  You need to short out the loom to get rid of the message. (There may be some tech2 trickery you can do as well.)   Have a look up under the wheel arch and you may see the end of the loom and a connector clipped to the inner wing (next to the abs cable).
I would leave it be, assuming you inspect pads regularly - the sensors cost the same or more as new pads and are a minor pain to fit.
« Reply #7 on: 16 May 2008, 15:34:25 »
Cheers
nathan
If no sensor on pads but wirings there & no warning message on MID, then wiring has been shorted out.  Is you follow wiring back towards inner wing u should find a plug.  If u unplug wiring should get low pad error on MID.  If thats the case u can buy new sensors, fit to pads & plug in - job done.
« Reply #8 on: 16 May 2008, 15:37:52 »
Had new a 98R GLS as a company car - this had front pad sensors, and was bought as a std car (apart from better anti theft and fitted car phone system).
ghondie
  • sheerness,kent,uk
« Reply #9 on: 16 May 2008, 16:31:57 »
kool ok will have a look, and see then.
Cheers
Nathan
Richard A
  • Aldridge, West Midlands
« Reply #10 on: 16 May 2008, 18:36:02 »
Back to "Juedu 2" disconnect plug/socket spray with WD40, then reconnect.
regards
richard a
richard a
