Author Topic: My oil leak!!!! grrrrrrrr  (Read 4695 times)
FRE07962128
Re: My oil leak!!!! grrrrrrrr
« Reply #15 on: 16 May 2008, 17:42:27 »
if you can get ur hands on a steam cleaner then do so, or a presure washer is the next best thing, give it a good wash, being careful of the ignition side of things i.e dis pack, then let it tick over and watch for leaks, as others have sugested look around the side and vally of the block - (oil cooler pipes)
pull a HT lead out  and look in wells-(cam cover)
and check around the front and back of block -(crank seals)
best of luck :y
at least you dont have to worry about rust  ;D
No, just fire! :'( :'(
HGV mechanic
  • northamptonshire
  • he just keeps on going,,,
« Reply #16 on: 16 May 2008, 17:45:12 »
best of luck :y
FRE07962128
« Reply #17 on: 16 May 2008, 17:47:33 »
best of luck :y
The song "Rocket Man" comes to mind with all that combustable oil!
 ;D ;D ;D ;D ;)
thomascdx24v
  • Northampton
« Reply #18 on: 16 May 2008, 18:06:47 »
thanks for all your help and advice. i had had a quick look at the rocker gaskets but couldnt see any signs but i willhave a closer look.
also some one mention the oil pipes from oil cooler. upon starting the car, the wirling coming from the oil cooler seems to be louder and longer then i have heard on others, any ideas?
hotel21
  • The Kingdom of Fife
« Reply #19 on: 16 May 2008, 18:14:17 »
?   Really need some more info to expand on this.  Remember the oil cooler on these engines is located deep within the V of the block, not to the front beside the water radiator as most other cars.  The 'wirling' may well be the secondary air injection fan on startup, anothr common fault.  Noise should stop after 30 seconds or so....
Is there oil in the plug lead wells?
Is oil visible running down the side of the engine?
thomascdx24v
  • Northampton
« Reply #20 on: 16 May 2008, 18:24:04 »
no visable oil running down the engine and i havnt het had the ht leads out. the wirl i refered to you say is the air injectors, shows how much my local garage know they told me it was oil cooler. the only sign of oil is at the front of the engine
hotel21
« Reply #21 on: 16 May 2008, 18:26:53 »
Remove the easy accesable HT leads and check for oil on them.  If they are wet or you can see oil down the plug wells, safe bet thats the culprit....
HGV mechanic
  • northamptonshire
« Reply #22 on: 16 May 2008, 18:27:12 »
crank seal ?? sump gasket??
thomascdx24v
  • Northampton
« Reply #23 on: 16 May 2008, 18:33:16 »
crank seal, where will i find that?
bobbertbear
  • perth
    • 04 omega 3.2 ex plod
« Reply #24 on: 16 May 2008, 18:35:46 »
i had the same thing on her indoors elite,it was the head gasket but on the passenger side bank,just leaking a bit but had to put about 2 liters of oil in a week. >:(
hotel21
« Reply #25 on: 16 May 2008, 18:36:34 »
why not check the easy obvious common failures first, ie rocker gaskets, so they can be eliminated?
Crankshaft pulley is down the bottom of the engine, front, between radiators and the block.
thomascdx24v
  • Northampton
My oil leak solved thanks to guys!!!!
« Reply #26 on: 16 May 2008, 18:41:00 »
U have just pulled out the HT leads and the wells were full to the brim with oil, im surprised the car was running!!!!!!
hotel21
« Reply #27 on: 16 May 2008, 18:45:32 »
http://www.omegaowners.com/forum/YaBB.pl?num=1152564281
Above shows how to change the gaskets (use gen VX not from a factors or e-bay) whilst the bottom link shows what else to do when you are in there to ensure that the engine is breathing correctly...
http://www.omegaowners.com/forum/YaBB.pl?num=1152598350
« Last Edit: 16 May 2008, 18:47:15 by hotel21 »
