Author Topic: dam codes again  (Read 1139 times)
madmorty
  • wirral
dam codes again
« on: 16 May 2008, 16:52:37 »
hi guys
   i have just checked my fault codes on my omega as it keeps on stopping dead as if its ran out of petrol the codes are 19 crankshaft sensor ,38 which i know about but cannot trace the fault,and code 92 camshaft sensor heater will i need to replace the crank sensor and cam sensor and are they easy to do
             many thanks
               al :exclamation
rickyboy
  • Glasgow
Re: dam codes again
« Reply #1 on: 16 May 2008, 17:14:29 »
Never had the two codes come up at the same time and I can't help feeling only one of them will need to be changed but which one?  Changing the crank sensor will probably get rid of both cam and crank codes.  Any symptoms, like car failing to start etc?
Code 38 is the o2 sensor - any holes in the exhaust?  Wiring ok to the sensor?  You'll need to test the sensor with a voltmeter to see if it's working ok.
« Last Edit: 16 May 2008, 17:15:54 by rickyboy »
Re: dam codes again
« Reply #2 on: 16 May 2008, 17:32:28 »
19 - Crank Sensor - deal with this 1st - other codes will probably clear as well.
markey mark
  • SLady bitshorpe north lincs
Re: dam codes again
« Reply #3 on: 16 May 2008, 18:57:18 »
as dbug says get the crank sensor changed then run it  a while and it should be ok !! :y
Re: dam codes again
« Reply #4 on: 16 May 2008, 20:46:53 »
I suspect the cam and crank sensors need changing - a failure on one of them should not cause a 2.0l to stop, but worth changing one first, then see what happens
Page created in 0.009 seconds with 20 queries.
