Author Topic: Help - Breather box pipe blocked....  (Read 1565 times)
Neil_MV6
  • Sutton Coldfield-West Midlands
« on: 16 May 2008, 19:39:18 »
Hi guys.
I'm doing my breathers and have a blocked pipe.  Its the smallest one, no. 3 as seen in the pic below:
I've stuck a long wire down the whole length of the pipe but it seems to be the bottom bit where it comes out of the middle that's blocked.
I took this picture from the maintenance guide and cant work out exactly where the exit point for this pipe (purple line) is.  If I know that, maybe I can unblock it.
I've prodded around as much as I can with a thin bag tie wire but am not certain where to poke?
Can anyone offer advice on clearing this please?
Cheers
Neil
« Last Edit: 16 May 2008, 19:40:48 by Neil_MV6 »
Richie London
  • heathrow
Re: Help - Breather box pipe blocked....
« Reply #1 on: 16 May 2008, 19:43:48 »
i used 2 cans of carb cleaner, and continous prodding, then aired out with wd40 after.
richie
hotel21
  • The Kingdom of Fife
« Reply #2 on: 16 May 2008, 19:44:51 »
There are pin holes in the circular portion as in the photo insert.
A strand from a wire brush, held in vice grips and wriggle it in with copious carb cleaner....
« Last Edit: 16 May 2008, 19:45:43 by hotel21 »
Neil_MV6
« Reply #3 on: 16 May 2008, 20:27:22 »
Bloody Hell!
I didn't notice the two pin holes in the picture and Mine were completely blocked and covered in crud so I couldn't see them.
2 sodding hours tryin to clear that pipe ....I could have had it all back together by now.  Bang goes my ly-in tomorrow morning. >:(
Might be a useful note to put on the maintenance guide for future users?
Cheers for the help guys, much appreciated.   :y
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« Reply #4 on: 16 May 2008, 23:10:01 »
Hi Neil I had the same would not move then put on the water hose , hose over the small hole and it will get all that muck out. Took 5 mins to clean all the holes.
When the water runs out clear you know your done :y
Hope that helps all the best
steven
Neil_MV6
« Reply #5 on: 17 May 2008, 10:02:27 »
Thanks Steven, it all clear now.
You did yours at the Cambelt party didn't you?
Now to fnd that coolant leak down th back somewhere..... :-/
