Author Topic: Cam gaskets  (Read 1283 times)
valliant72
  • London
Cam gaskets
« on: 16 May 2008, 19:23:27 »
Hi all, can u have the cam cover gaskets go even though the breathers are clear, cause i have an oil leak from the cam covers, so i checked the breathers and there clear, no resistance at all and pipes were clean. Gonna sort the cam gaskets next week, but just wondered if they go just through age.
hotel21
  • The Kingdom of Fife
Re: Cam gaskets
« Reply #1 on: 16 May 2008, 19:26:51 »
Yes, they can go through age but, if fitted correctly (clean surfaces, sealer in the correct places, tightened to correct torque) can last the life of the engine, especially if the breathers are clear.
If they have been replaced with non VX ones, their life span can be a handfull of months, sometimes a lot less.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Cam gaskets
« Reply #2 on: 16 May 2008, 21:27:58 »
Have you followed the breather pipes done to the breather box? it has a very small hole the size of a needle plus one about 12-13mm...
The small one does get blocked when not oil changed regular :y
valliant72
  • London
Re: Cam gaskets
« Reply #3 on: 16 May 2008, 23:10:37 »
Thanks for ur replies, yeah i checked the breather box and they were ok, the lil pin size one was clear aswell, im not sure if the leak was cause by the guy who sold it to me had steam cleaned the engine. Hopefully nothing else will go wrong, especially electrical wise, but touch wood, everything else has been ok.
« Last Edit: 16 May 2008, 23:11:19 by valliant1 »
Policychecker
  • Northern Ireland
Re: Cam gaskets
« Reply #4 on: 17 May 2008, 16:30:53 »
what about if the breather pipes were put on the wrong way or mixed up?
Page created in 0.009 seconds with 20 queries.
