Author Topic: LPG fiddling  (Read 3879 times)
HolyCount
Re: LPG fiddling
« Reply #15 on: 17 April 2008, 19:52:55 »
Might be an option later -- would like to do it -- but know zilch about conversions and local shop want £1400 just for front end !!!!
Martin_1962
Re: LPG fiddling
« Reply #16 on: 17 April 2008, 20:07:57 »
Easier to DIY
Jay w
  • Plymouth/Poole
  • omega gone
Re: LPG fiddling
« Reply #17 on: 17 April 2008, 20:18:21 »
Count, it is not that hard to do......
If everything goes to pan then i will be doing the CDX soon, what i intend on doing is trying to put together something with a few pics on install and fitting......
A front end kit is easy, i would have said a day and a half at the most, for me the most difficult bit was the blood pipe work and tank
HolyCount
Re: LPG fiddling
« Reply #18 on: 17 April 2008, 21:05:25 »
Easier to DIY
Dam sight cheaper too -- that price was before the dreaded VAT!
Jay -- would be interested in seeing the pics and guide --- but THB I haven't worked under a bonnet for the last 20 years  -- back then the engines might as well have been clockwork compared to the Omegas !!!
Jay w
  • Plymouth/Poole
  • omega gone
Re: LPG fiddling
« Reply #19 on: 17 April 2008, 21:11:31 »
Easier to DIY
engines are engines mate  ;)
there seems to be a bit of confusion with LPG kits, people seem to think that they require a high level of mechanical involvement.
the only thing that is required is to break into the heater hose and then drill and tap 7 holes (6 injector and 1 MAP sensor feed) in the inlet manifold, the rest of it is either parts fitting or wiring.
I am no expert but having done one i feel confident enough to attempt a second and would be happy to assist someone in the same way that James and Kevin have in the past
pretty much as soon as the CDX is running we start the LPG kit, i just need to get the thing to a point where we know it is good before we start adding extra fuel types to the equation
« Last Edit: 17 April 2008, 21:13:00 by jay_w »
HolyCount
Re: LPG fiddling
« Reply #20 on: 17 May 2008, 20:59:10 »
Easier to DIY
Jay, how 're things going with getting the CDX up and running ?
