Author Topic: Vibration from Clutch pedal  (Read 1892 times)
jules
  • Edinburgh
  • Woke up this morning a post whore
« on: 17 May 2008, 17:14:16 »
Over the last couple of days I have noticed a vibration from the clutch pedal.
It is apparent when I rengage the clutch after changing gear and also apparent when engine breaking.
It is only a very slight vibration but it was not there last week.
Is my clutch/thrust bearing on it's way out or could my gearbox be needing oil?
Cheers guys
Hotel21 wrote 'Its doubtfull in the extreme if it is the head gasket at fault.  If it were burning 5 litres per week the car would leave a smokescreen behind it!'
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Vibration from Clutch pedal
« Reply #1 on: 17 May 2008, 20:57:59 »
Well, the easy part is to check the box oil level, then go from there.
I like red cars
Taxi_Driver
« Reply #2 on: 17 May 2008, 21:34:07 »
Is the vibration a judder when releasing the clutch? and only when the clutch is hot?
If so both my veccies did that.......the veccyB was cured with a new clutch kit.......dunno what the problem was with the veccyC, probably the same....as i sold it  ;D
